Posts: 32 |
Has anybody had to replace their lower control arms? If so what were the symptoms? I was told I need to replace mine, but thought I would get an opinion from the guys that really know contour, thanks
2000 CSVT #1886 of 2150
Mods? On the way
Stay Classy
Posts: 21,197 |
Symptoms? Front suspension noises sometimes. While someone else is driving watch the front wheels. When they let out the clutch you can see the wheels jump. Car will also tramline pretty bad depending on road conditions. 2 bolt LCA's usually wear out within 80k miles. They are $100 for the pair from Jenkins and aren't as hard to replace as the early 4 bolts. I can do them for you if you want to make a trip to Grand Rapids.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 540 |
Somebody has actually replaced the LCAs in a Contour??
'98 SVT Red/midnight blue - a few mods
E0 wheels for sale - PM me
Posts: 4,140 |
Take a look at the bushings. Jack the car up and try to move the wheel around - if the bushings aren't nice and tight, you'll need new arms. This is a very common issue. They're a wear item, especially on the 2-bolts like you have.
Posts: 21,197 |
Originally posted by Hdbngr8: Somebody has actually replaced the LCAs in a Contour??
LOL! Tis true.
-'96 SE MTX 3L
Posts: 540 |
Maybe I need to check into that.
Posts: 712 |
I've replaced both of mine, honestly an easy job
1998.5 Diamond White Pearl SVT (#4725)
custom exhaust/intake k&N/mod'ed y-pipe
slotted rotors/greenstuff pads/SS lines
cougar trans/FSVT shift tower/Torsen
16lb. flywheel
18" Velox VX-8's with some rubba bands
Posts: 21,197 |
If you have the tools to pop the control arms out of the hub and an impact to push the axles out then yes.
-'96 SE MTX 3L
Posts: 3,570 |
A SVT in TC eh? Hmmm... I'll keep my eyes open for that one
Posts: 2,033 |
on spmotorsports they have either vertical or horizontal..witch one fits a 99 svt?
