Posts: 296 |
mine the same problem misfire and only have 8000miles i have buy it a black tape that use for stereos and wraped all the wires and stop misfire  i know is a temporal solution (i have 2 months with this solution)
Posts: 1,423 |
so far I'm loving my Magnacores
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
Posts: 4,639 |
i've had mine for about 45k and no misfire as far as i can tell. does the engine just turn over and not start up right away when it misfires?
Hugo AIM:omegazodiac
Posts: 6,791 |
A blinking CEL usually follows a misfire.
Posts: 5,810 |
Originally posted by Pole120: Just re-installed my 100k stock wires because after only 7k of use the FRPPs developed a missfire. Can i get my money back to go buy a QUALITY product?
Possibly you can change out the coil. The coil-wires-plugs on our cars' ignition systems all really go together to create a certain impedance in the ignition system (duh right?) Anyway, the wires may have a different resistance and that combined with your coils (no two coils are exactly alike) and your plugs may be causing a bunch of noise on the coil driver circuits in the PCM. This will cause misfires on otherwise good components. I suggest you try a couple of differen't cheap plugs like non-platinums with those wires and see what happens. Also, just change the plug gap on the plugs you have. Tighten it up by 5-10 thousands, see what happens and then compare by widening the gap by the same amount....all on the same plugs. This way you can see what the effect is with just different plug gap, then try a differen't plug if you haven't gotten the problem to go away.
See My Mods
Posts: 4,141 |
I've had two different coils on the car(nice having extra parts around sometimes), and the problem persisted. I have not however done enything with different plugs. I've been looking for an excuse to justify Magnacores and it's been given to me. The misfire is gone now that i've re-installed teh stock wires.
~Josh
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 540 |
'98 SVT Red/midnight blue - a few mods
E0 wheels for sale - PM me
Posts: 9,872 |
Josh, try using a different plug, I know I had missfire for the longest time due to Autolite DP plugs with Magnecor 8.5mm..I took Pete (mapoftazi) advice and bought cheap Champion .99 cent plugs and the car runs beautifully
Posts: 4,714 |
Originally posted by RawBurt...: A blinking CEL usually follows a misfire.
Not always. Josh's misfire was similar to what I experienced in my Sport. The car idled and accelerated just fine in regular traffic, but get it up to freeway speeds (60-70) and floor it in top gear; the engine bogs and bucks. I'm not even sure you could call it a misfire as much as it was just an "ignition problem." The few times I have experienced a blinking CEL with other people's cars (never my own) was when the misfire was so bad that the car could barely hold idle.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 4,714 |
Originally posted by Pole120: I've had two different coils on the car(nice having extra parts around sometimes)
<*COUGH*>you're welcome<*COUGH*>
I keed!
Hooray Beer.
Pictures
