Posts: 16 |
Originally posted by Tony2005: ..or remove the blower and hot wire to the battery. If it works, you know it is not the blower. But I suspect you will see some melted wires or connectors near the resistor when you are at that point.
How do I do that the chilton book doesnt show how to test it.
Posts: 16 |
Well thanks for all the help, so I tested the blower to find out its dead, so going to check the resistor.
Posts: 16 |
The resistor is good so it's a bad blower.
Posts: 1,788 |
Did you measure the voltage at BOTH terminals of the blower as I previously suggested?
If you had 12.18 volts on BOTH terminals, then the problem is not the blower, but is an open to ground, most likely the blower speed selector switch.
If you measured 12.18 VDC on one of the terminals and 0 Vdc on the other, then the blower motor is open-circuited.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 16 |
Originally posted by projectSHO89: Did you measure the voltage at BOTH terminals of the blower as I previously suggested?
Steve
Yeah I did get a measurement of 12.18 VDC from the connector that goes to the blower, but the other guy told me to switch it to ohm and check the blower itself and kept an infinite number(never showed zero).
Posts: 5,345 |
Originally posted by deshaundsm: Originally posted by projectSHO89: Did you measure the voltage at BOTH terminals of the blower as I previously suggested?
Steve
"The other guy" is now asking, Are you sure you tested the blower correctly? Maybe you should hot wire the blower to the battery to confirm if the blower works.
Originally posted by Tony2005: ...Remove blower, then open hood, connect two wires from the battery to blower.
1996 V6 ATX 96K miles
Posts: 16 |
Im going to try hot wiring,I should post within 30min with results.
Posts: 16 |
Sorry, I forgot your name tony. Ok to the results :sigh: its dead . Ok well off to the junkyard I go.
