Posts: 587 |
Just wondering if anyone can pass smog with an open air filter intake. I have to get my car smogged before i take it apart to do my 3L swap.
Thanks
3L process done
Posts: 35 |
just make sure theres a CARB sticker on it...haha
from my experience...its usually just visual failiure for having an aftermarket cai..
Posts: 3,496 |
No,
you need to put the stock intake back on. It will fail visual.
Posts: 587 |
Alright good thing I kept that somewhere.
Thanks for the quick help!
3L process done
Posts: 2,353 |
Actually, you can legally pass with an open air filter as long as all of the sensors are in their stock location. CARB doesn't apply as long as the modifications are still being monitored by the OBD sensors in the stock locations. So a CAI will fail as they usually move the MAF and sensors, but an open air filter in the stock location will be fine.
I left my K&N on all three times I had my car smogged (at three different locations) with no problems at all.
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 5,882 |
ive always passed smog with an open filter no problem. no carb stickers or nuttin.
Posts: 1,325 |
I got turned away for my filter once, they let me go change it back to stock before doing the test. They said it would fail right off the bat unless there was a CARB number on it. Maybe they were just being overzealous?
97 Contour SE MTX
04 Grand Caravan SXT
Posts: 2,353 |
Most likely they just did not know the laws completely. With CARB being such a royal pain in the rear, many places will error on the side of caution. Then again, many other places will look the other way for just about anything for the right $, so it goes both ways. Heck, I still have the CARB sticker that I got with my old Ranger's K&N drop in that I could just slap on anything. Well, if I still owned a car that is...
2003 Suzuki SV650s
Posts: 1,228 |
my SVT failed a visual with the KKM, but it pretty much all depends on 'who' you go to... if you pick jim bob's SMOG station it will probably be less of an issue than if you go to a state funded station  lucky me, my Injen CAI has a CARB Plate - i hope it works!
Posts: 587 |
Failed smog today... I swapped out my SHO-Shop intake for the stock one then took it in to get tested. Comprehensive Visual Inspection: PASS Functional Check: FAIL Emissions Test: PASS I failed because I unhooked my battery from the car to swap out the intakes. They needed old records of my driving... Now I have to drive around 40 miles and get it retested. Also use up my lunch break again
3L process done
