N
N
0401 and 0402 EGR insufficient and excessive at the same time i have heard this can mean the DPFE sensor. and what does DPFE stand for?
2000 T-red SVT #1049 of 2150
Not Sure Without Looking It Up What It Stands For. But If You Go Down To Duratec Maintenance And Search For: "Tie Rod Ends" For Some Reason It Brings Up A Decent Thread About The DPFE Replacement And It's Location With Pics.
Also You Can Just Search "DPFE" And A Slew Of Previous Posts Will Pop Up That You Can Read Through And Make A Judgement As To What You Need To Do. Good Luck. Post With Any More Questions.
Oh And It Means: "Differential Pressure Feedback EGR"
CSVT E0 3L 14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
I actually have a question... Why do you post with every first letter capitalized? Im not trying to be rude or anything, I just have always noticed that you have done that... any particular reason?
DPFE - Differential Pressure Feedback EGR (Exhaust Gas Recirculation). It is also known as the EGR Backpressure Transducer.
While it could be a faulty DPFE sensor, I would suggest testing it first. This thread has the how to for P0402.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1261255&page=2&view=collapsed&sb=5&o=31&fpart=1
In addition, from Ford CD manual, P0401.
Diagnostic Trouble Code (DTC) P0401 indicates that Continuous Memory Self-Test has detected insufficient EGR flow.
Possible causes:
-- EGR valve stuck closed or iced.
-- EGR valve diaphragm leaks.
-- EGR valve or flow path restricted.
-- EGR vacuum hose off, plugged or leaks.
-- VPWR circuit open to EGR Vacuum Regulator (EGR V.R.) solenoid.
-- EVR circuit to PCM open.
-- EVR circuit to PCM shorted to PWR.
-- Differential Pressure Feedback EGR (D.P.F. EGR) sensor pressure hoses both off.
-- D.P.F. EGR sensor pressure hoses reversed.
-- D.P.F. EGR sensor VREF circuit open.
-- Downstream pressure hose off.
-- Downstream pressure hose plugged.
-- Damaged orifice tube assembly.
-- Damaged EGR V.R. solenoid.
-- Damaged D.P.F. EGR sensor.
-- Damaged PCM.
