Page 3 of 3 1 2 3
#1593171 06/19/06 04:19 PM
Originally posted by BlackE1:
Try this
Winner!!!
#1593172 06/19/06 04:19 PM
Thanks, I just found that post about 2 mintues ago while searching.
#1593173 06/19/06 04:20 PM
Originally posted by RawBurt:
Heres an idea, dont get either of those... Unless you want to cut a rectangle in your fender
Whats wrong with making side markers fit on the car? It�s not like there�s a gaping hole in the fender.
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998 WR Headers GMK CAI Blaupunkt system fiberglass tweeter pods L.E.D. tail lights in the works
#1593174 06/19/06 05:00 PM
How about these guys? Looks like they will go on with little modding, but how do you think they will look?
I am just going for something cheap.. what do you guys think?
#1593175 06/19/06 05:16 PM
The first ones look like they'll fit very nicely after dremeling that tab off. The second ones, Im having a hard time determining whether they'll fit or not. Just try em and see what happens... That way if they dont work, you wont have to worry because you went cheap
#1593176 06/19/06 05:34 PM
Originally posted by ConcepTrs913:
Yes if you removed the tabs they might fit but it looks like to me that they have a taper that would prevent them from sitting flush with the fender just like the first Audi A4s you posted.
#1593177 06/19/06 05:39 PM
FAQ: Free / Cheap Mods is a very good place to start.
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
#1593178 06/19/06 08:50 PM
I
I
Originally posted by KerryKool:
Led mods, all of them. Window switches, lock switches, clock, guages, etc. I'm doing the interior set as soon as I get my leds. Its really cheap, just takes some time.
+1
Relatively easy, relatively cheap, and you can't argue with the results!
#1593179 06/19/06 09:01 PM
W
W
Were did you find these? I'm looking to replace mine and these are fastened the same way mine are. They were already on the car when I got it so I want to try and stick with the same fastening method.
WA 2 TUFF SVT 2000 Tropic Green SVT Born 1/28/2000-1975 out of 2150-only 207 made. Some new pics
#1593180 06/19/06 09:06 PM
Z
Z
Originally posted by SVZETEC:
I used these...small but bright. I got clear w/ amber led's:
The hole size is 11/16", just under an inch & it took a wee bit of grinding from the die-grinder to open them up...not much at all.
What exactly is the model of that light, cause I like the discrete style of that... just enough to cover up the hole behind the badge while giving you a small turnsignal/sidemarker. I see the image is from customdynamics.com but not sure where on the site they are located. any help?
thanks
98 Black Contour SVT #1273 Born the 23rd of June, 1997
Page 3 of 3 1 2 3
