Posts: 6,791 |
Originally posted by BlackE1: Try this
Winner!!!
Posts: 343 |
Thanks, I just found that post about 2 mintues ago while searching.
Posts: 853 |
Originally posted by RawBurt: Heres an idea, dont get either of those... Unless you want to cut a rectangle in your fender
Whats wrong with making side markers fit on the car? It�s not like there�s a gaping hole in the fender.
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 343 |
How about these guys? Looks like they will go on with little modding, but how do you think they will look? I am just going for something cheap.. what do you guys think?
Posts: 6,791 |
The first ones look like they'll fit very nicely after dremeling that tab off. The second ones, Im having a hard time determining whether they'll fit or not. Just try em and see what happens... That way if they dont work, you wont have to worry because you went cheap
Posts: 853 |
Originally posted by ConcepTrs913:
Yes if you removed the tabs they might fit but it looks like to me that they have a taper that would prevent them from sitting flush with the fender just like the first Audi A4s you posted.
WR Headers GMK CAI
Posts: 5,975 |
FAQ: Free / Cheap Mods is a very good place to start.
Posts: 1,882 |
Originally posted by KerryKool: Led mods, all of them. Window switches, lock switches, clock, guages, etc. I'm doing the interior set as soon as I get my leds. Its really cheap, just takes some time.
+1
Relatively easy, relatively cheap, and you can't argue with the results!
Posts: 2,426 |
Were did you find these? I'm looking to replace mine and these are fastened the same way mine are. They were already on the car when I got it so I want to try and stick with the same fastening method.
Posts: 144 |
Originally posted by SVZETEC: I used these...small but bright. I got clear w/ amber led's:
The hole size is 11/16", just under an inch & it took a wee bit of grinding from the die-grinder to open them up...not much at all.
What exactly is the model of that light, cause I like the discrete style of that... just enough to cover up the hole behind the badge while giving you a small turnsignal/sidemarker. I see the image is from customdynamics.com but not sure where on the site they are located. any help?
thanks
98 Black Contour SVT
#1273
Born the 23rd of June, 1997
