Yes, look at the picture. Have you seen the hole behind the badge? Its a small circular hole that�s size of the circle where the light plugs into on the back of the A4 lights (in the above pic). If you want them flush mounted then you will need to either cut the light down, or make the hole in you fender fit the light.
If you cut the light down your doing to cut the backside of the light away and the light bulb will have nothing to reflect on.
Or just buy lights that will fit with out modification, but I liked the look or the clear A4 lights.
