Posts: 1,746 |
I haven't had the use of my E-Brake for some time now...and I sorta want to get it back. Before the winter I actually broke the cable that goes from the handle to the braket where it splits off to the rear cables. I checked @ Jenkins site for a replacement and it was $72.XX I thought that was rediculous just for a cable. Does anyone know of an alternative source for the cable? TIA
2000 Contour SVT
SF - #542 of 2150
Posts: 4,639 |
junkyard. and that price i believe is for the entire kit. cables for both sides and new springs for the calipers. i replaced my cables with that kit and no more stuck ebrake in the winter. didnt happen once this winter, like it was doing almost daily last winter
Hugo AIM:omegazodiac
Posts: 140 |
I looked into the hand brake cables on fordpartsonline.com just a couple weeks ago and they have seperate part #s for the front cable and rear cable, I think the front was a whole $35+ and the rear was something close to that as well.
1999 Black/Tan CSVT
#2658 of 2760
201,000+km
- K&N, Magnecor race wires, Optima red top, BAT Euro Kit, KVR CF pads, PIAA Plasma Ion bulbs.
1989 Yamaha FZR600 - 40,000+km
- K&N Pods, Stage 3 Jets, V&H 4-1 exhaust
Posts: 4,639 |
ebrake only runs to the rear calipers. there is no front. u might be checking the front ebrake lever which is the whole piece with the actual handle u pull. otherwise theres 2 cables: a left and right that go to the rear calipers and newer springs that r supposed to be better at releasing the ebrake to not stick. the cables attach to a y split thats part of the front ebrake lever
Posts: 6,760 |
Originally posted by hmouta: ebrake only runs to the rear calipers. there is no front. u might be checking the front ebrake lever which is the whole piece with the actual handle u pull. otherwise theres 2 cables: a left and right that go to the rear calipers and newer springs that r supposed to be better at releasing the ebrake to not stick. the cables attach to a y split thats part of the front ebrake lever
According to the Ford CD there is a 'front cable.' I had to recently diagnosis why my calipers were frozen, and the CD specific states it as a 'front cable.'
Ryan
Trollin!
Posts: 712 |
just call bill.. he'll know (well he usually knows parts pretty well) i got an ebrake cable from him for i think like $40 and it runs from both calipers to a cable that is up above the muffler(resonator) and heat sheild. There is a "front cable" that goes from that point up to the actual handle. Most likely your problem resides in the rear cable.
this bia fixed my MPG from 21ish to 25ish
1998.5 Diamond White Pearl SVT (#4725)
custom exhaust/intake k&N/mod'ed y-pipe
slotted rotors/greenstuff pads/SS lines
cougar trans/FSVT shift tower/Torsen
16lb. flywheel
18" Velox VX-8's with some rubba bands
Posts: 5,345 |
Originally posted by RTStabler51: Originally posted by hmouta: ebrake only runs to the rear calipers. there is no front. u might be checking the front ebrake lever which is the whole piece with the actual handle u pull. otherwise theres 2 cables: a left and right that go to the rear calipers and newer springs that r supposed to be better at releasing the ebrake to not stick. the cables attach to a y split thats part of the front ebrake lever
Also from Autozone. Front cable. http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/d9/47/0900823d801bd947.jsp
1996 V6 ATX 96K miles
Posts: 1,746 |
And I know it is the front cable, simply because it has frayed/snapped (in 2 pieces) right where it enters the car.
2000 Contour SVT
SF - #542 of 2150
Posts: 183 |
If it is the "front cable" I am also positive you have to replace the whole handle which has the cable attached. I have had to do twice. Once a new part from Ford and once out of a junk yard. Both times the cable frayed and broke.
Rich S
1998 SVT
1995 Contour 2.5 MTX 215K miles Son's car(dead and buried)
1997 Contour 2.0 ATX
1998 Contour 2.5 ATX
2004 Tauras Wagon 3.0 Duratec
Posts: 140 |
Originally posted by richs: If it is the "front cable" I am also positive you have to replace the whole handle which has the cable attached. I have had to do twice. Once a new part from Ford and once out of a junk yard. Both times the cable frayed and broke.
Rich S
With the hand brake removed from the car body floor and the front cable detached from the rear cable you will be able to retract the brake handle all the way back and align the cable knuckle removal holes.. hard to explain without pics, but you really shouldn't have to replace the E-brake itself unless it's failed like mine has , if it's just a frayed cable near the ebrake then he should be ok.
1999 Black/Tan CSVT
#2658 of 2760
201,000+km
