Originally posted by Stylin55_oh:
so do i have everything i need? i have the following
~struts
~ground controls
~camber correction kit(with upgraded plates)
do i need?
~strut mount?
~axle nut? (they say they are only good for like 3 times.. ive taken mine on and off more than that for sure)
fyi axle nuts are a one time use item, think about it they get torques to 210 ft/lbs, and you don't need to pull the axle out of the hub to change the struts unless you fear hyperextending the c/v joint when moving the hub around
