Posts: 926 |
Hey, Im trying to figure out how to build a server and I have some questions. First off, this is the motherboard an CPU Im looking towards Clicky . My biggest question is will I be able to run these UDMA Hard Drives 1) without a RAID controller and 2)How bad will the disk reading load be? Im trying to avoid SCSI because of the high cost, and I was told that even though the over all speeds between SCSI and UDMA arent that different the SCSI drives allow for multiple reads while the UDMA only allow single. Im not sure which direction to go. If it matters at all Id like to run Mandrake linux. Thanks for any help
Ben C '97 Zetec Sport ATX Pacific Green Fog Light Re-wire Many Mods My Site
You think you can beat this?.....Well, you probably can
Posts: 4,476 |
hmm - i was with you until i clicked the link...
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
Posts: 926 |
Try the links again, they are kind of picky but will eventually load. If not:
AMD AthlonŽ XP 2100+ Boxed CPU With Soyo KT333 Dragron Lite Motherboard
Processor Supports AMD Socket-A AthlonXP, Athlon and Duron processors
Chipset Type VIA KT333
Chipset Description VIA KT333 / 8233A chipset Supports 200/266 MHz FSB
Form Factor ATX
Memory Type DDR333 SDRAM
Memory Description Three DDR 2.5V DIMM sockets support up to 3GB PC2100/PC2700 non-ECC, unbuffered SDRAM memory
Expansion Slots Five 32-bit Bus Mastering PCI slots (V2.2 compliant) One Universal AGP Pro slot (support 1x/2x/4x mode)
IDE Description Four independent channels for 8 IDE devices (2 for RAID) Supports up to PIO Mode 5 and UDMA 66/100 Two PCI Bus Mastering ATA E-IDE ports
Audio Description On board CMI 8738 chip providing 4-channel hardware audio solution
IO Port Description Two RS-232 serial ports (16550 UART compatible) One parallel printer port (SPP/EPP/ECP mode) One FDD port (supports 3 mode, 1.2/1.44/2.88MB) IrDA ports with optional cable for transceiver Six standard USB ports (2*rear, 2*front)
IO Connection Description PS/2 Mini-DIN mouse and keyboard ports Two standard USB ports Two D-Sub 9-pin male serial ports One D-Sub 25-pin female printer port Audio I/O: Line-Inx1, Line-Outx1, MIC JACKx1 One game port
BIOS Description Award PCI BIOS with ACPI function Supports multiple-boot from E-IDE/SCSI/CD-ROM/FDD/LS120/ZIP 2 Mbyte Flash ROM
Health Monitoring Description On board voltage monitors CPU fan speed monitor CPU temperature monitoring through flexible thermal sensor
Dimension Description Four layers, 30.5 cm x 24.5 cm (12" x 9.6") ATX form factor
Compatibilities WinXP / Win2000 / WinNT / WinME / Win98SE / Linux / FreeBSD
Warranty All SOYO motherboards are designed to offer stability and flexibility, and are tested to ensure highest reliability. We offer 1 year limited warranty on all SOYO motherboards.
Posts: 926 |
Western Digital 30GB WD300BBRTL UDMA100
Performance Specification s Average Read Seek 8.9 ms (average) Track to Track Seek 2.0 ms (average) Full Stroke Seek 21 ms (average) Average Latency 5.0 ms Rotational Speed 7200 RPM Transfer Rate: (Buffer to Host) 100 MB/s (Mode 5 Ultra ATA) 66.6 MB/s (Mode 4 Ultra ATA) 33.3 MB/s (Mode 2 Ultra ATA) 16.6 MB/s (Mode 4 PIO) 16.6 MB/s (Mode 2 multi-word DMA) Buffer Size 2 MB Contact Start/Stop Cycles (CSS) 40,000 minimum
Posts: 4,476 |
ok - so i was with ya until you picked the Athlon so you're looking to buy a cpu, motherboard and a harddrive? what else do you have around to finish the system with?
Posts: 926 |
256MB 184Pin DDR PC2100 Memory (2x)
Norcent 24x10x40 EIDE CD-RW Drive
Pc Micro Center PCM-3000 350W P4 Mid Tower ATX Case: New Media NMT0100A PC Card NIC 10/100 ENET
8MB Video Card
Thats what I have so far, my total is currently @ $750.00
Posts: 4,476 |
so here's a screamin deal... http://mate.pricewatch.com/scripts/b.asp?3128049 Intel P4 1.6GHz (Running @ 2.4GHz, 600MHz FSB) Northwood PC3200 400MHz DDR DIY (Complete Tested OverClock Kit) Epox 4BDAE Motherboard 256MB PC3200 DDR Thermaltake CPU Cooler Sale price: $325!!! slap in a harddrive and you're off and running!
Posts: 118 |
Athlon 0wnZ, Intel sUx0rs.
2001 ATX V6 Dark Shadow Grey Merc Cougar(Sport Pkg, ABS, traction control and sunroof :))
Posts: 4,476 |
Originally posted by Sasmaster6000: 256MB 184Pin DDR PC2100 Memory (2x) Norcent 24x10x40 EIDE CD-RW Drive Pc Micro Center PCM-3000 350W P4 Mid Tower ATX Case: New Media NMT0100A PC Card NIC 10/100 ENET 8MB Video Card Thats what I have so far, my total is currently @ $750.00 so you're looking for mobo/cpu/hd only - right?
Posts: 4,476 |
goto www.pricewatch.com search for Hard Disk Drives EIDE 80.0GB 7200 - you'll find IBM 80GB drives for $85 to the door your Athlon2100 setup goes for $225 there... saving you money but if you want a real CPU/MB for ~$350 - search for this... Motherboard Combos Pentium 4 2.2GHz with cpu, fan DDR 845
