#159122 07/03/02 10:41 PM
Hey, Im trying to figure out how to build a server and I have some questions.
First off, this is the motherboard an CPU Im looking towards Clicky . My biggest question is will I be able to run these UDMA Hard Drives 1) without a RAID controller and 2)How bad will the disk reading load be?
Im trying to avoid SCSI because of the high cost, and I was told that even though the over all speeds between SCSI and UDMA arent that different the SCSI drives allow for multiple reads while the UDMA only allow single. Im not sure which direction to go.
If it matters at all Id like to run Mandrake linux.
Thanks for any help
Ben C
'97 Zetec Sport ATX
Pacific Green
Fog Light Re-wire
Many Mods
My Site
You think you can beat this?.....Well, you probably can
#159123 07/03/02 11:21 PM
hmm - i was with you until i clicked the link...
frown
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
#159124 07/03/02 11:57 PM
Try the links again, they are kind of picky but will eventually load. If not:
AMD AthlonŽ XP 2100+ Boxed CPU With Soyo KT333 Dragron Lite Motherboard
Processor
Supports AMD Socket-A AthlonXP, Athlon and Duron processors
Chipset Type
VIA KT333
Chipset Description
VIA KT333 / 8233A chipset
Supports 200/266 MHz FSB
Form Factor
ATX
Memory Type
DDR333 SDRAM
Memory Description
Three DDR 2.5V DIMM sockets support up to 3GB
PC2100/PC2700 non-ECC, unbuffered SDRAM memory
Expansion Slots
Five 32-bit Bus Mastering PCI slots (V2.2 compliant)
One Universal AGP Pro slot (support 1x/2x/4x mode)
IDE Description
Four independent channels for 8 IDE devices (2 for RAID)
Supports up to PIO Mode 5 and UDMA 66/100
Two PCI Bus Mastering ATA E-IDE ports
Audio Description
On board CMI 8738 chip providing 4-channel hardware audio solution
IO Port Description
Two RS-232 serial ports (16550 UART compatible)
One parallel printer port (SPP/EPP/ECP mode)
One FDD port (supports 3 mode, 1.2/1.44/2.88MB)
IrDA ports with optional cable for transceiver
Six standard USB ports (2*rear, 2*front)
IO Connection Description
PS/2 Mini-DIN mouse and keyboard ports
Two standard USB ports
Two D-Sub 9-pin male serial ports
One D-Sub 25-pin female printer port
Audio I/O: Line-Inx1, Line-Outx1, MIC JACKx1
One game port
BIOS Description
Award PCI BIOS with ACPI function
Supports multiple-boot from E-IDE/SCSI/CD-ROM/FDD/LS120/ZIP
2 Mbyte Flash ROM
Health Monitoring Description
On board voltage monitors
CPU fan speed monitor
CPU temperature monitoring through flexible thermal sensor
Dimension Description
Four layers, 30.5 cm x 24.5 cm (12" x 9.6")
ATX form factor
Compatibilities
WinXP / Win2000 / WinNT / WinME / Win98SE / Linux / FreeBSD
Warranty
All SOYO motherboards are designed to offer stability and flexibility, and are tested to ensure highest reliability. We offer 1 year limited warranty on all SOYO motherboards.
Ben C
'97 Zetec Sport ATX
Pacific Green
Fog Light Re-wire
Many Mods
My Site
#159125 07/03/02 11:59 PM
Western Digital 30GB WD300BBRTL UDMA100
Performance Specification
s Average Read Seek 8.9 ms (average)
Track to Track Seek 2.0 ms (average)
Full Stroke Seek 21 ms (average)
Average Latency 5.0 ms
Rotational Speed 7200
RPM Transfer Rate:
(Buffer to Host) 100 MB/s
(Mode 5 Ultra ATA) 66.6 MB/s
(Mode 4 Ultra ATA) 33.3 MB/s
(Mode 2 Ultra ATA) 16.6 MB/s
(Mode 4 PIO) 16.6 MB/s
(Mode 2 multi-word DMA) Buffer Size 2 MB Contact Start/Stop Cycles (CSS) 40,000 minimum
Ben C
'97 Zetec Sport ATX
Pacific Green
Fog Light Re-wire
Many Mods
My Site
#159126 07/04/02 01:34 AM
ok - so i was with ya until you picked the Athlon eek
so you're looking to buy a cpu, motherboard and a harddrive? what else do you have around to finish the system with?
#159127 07/04/02 01:43 AM
256MB 184Pin DDR PC2100 Memory (2x)
Norcent 24x10x40 EIDE CD-RW Drive
Pc Micro Center PCM-3000 350W P4
Mid Tower ATX Case:
New Media NMT0100A PC Card NIC 10/100 ENET
8MB Video Card
Thats what I have so far, my total is currently @ $750.00
Ben C
'97 Zetec Sport ATX
Pacific Green
Fog Light Re-wire
Many Mods
My Site
#159128 07/04/02 01:44 AM
so here's a screamin deal...
http://mate.pricewatch.com/scripts/b.asp?3128049
Intel P4 1.6GHz (Running @ 2.4GHz, 600MHz FSB) Northwood PC3200 400MHz DDR DIY (Complete Tested OverClock Kit)
Epox 4BDAE Motherboard
256MB PC3200 DDR
Thermaltake CPU Cooler
Sale price: $325!!!
slap in a harddrive and you're off and running!
#159129 07/04/02 05:57 AM
N
N
Athlon 0wnZ, Intel sUx0rs. wink
2001 ATX V6 Dark Shadow Grey Merc Cougar(Sport Pkg, ABS, traction control and sunroof :))
#159130 07/04/02 04:41 PM
Mid Tower ATX Case:
8MB Video Card
so you're looking for mobo/cpu/hd only - right?
#159131 07/04/02 04:52 PM
goto www.pricewatch.com
search for Hard Disk Drives EIDE 80.0GB 7200 - you'll find IBM 80GB drives for $85 to the door
your Athlon2100 setup goes for $225 there...
saving you money smile
but if you want a real CPU/MB for ~$350 - search for this...
Motherboard Combos Pentium 4 2.2GHz with cpu, fan DDR 845
Moderated by  Fmr12B_dup1, path914
