Posts: 246 |
How about these. They have an offset that will allow them to fit on the inside but you will probably have to crazy with the fender rolling. Keskin cup style wheels They also have other wheels available in 4X108
'00 CSVT Koni/B&G (New), SCA intake, 18 inch Falken Circuit Spec (gunmetal), CF hood, Headlights by Dan, Mirko, deleted front license plate/painted chrome ring. Headers/y pipe installed - TruBendz Borla system no Res and optimized TB. Getting there!
Posts: 7,025 |
I can tell you right now that 8.5" wide wheels will give you some trouble. My 19x8 Axis wheels do hit the fender in the rear ever so slightly. They are pretty much as close to the strut as you can make them too. You might be able to make them work with some serious fender cutting and a few more mill's closer to the strut. I think you might have to run some pretty small tires though just to clear them though.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 4,639 |
Originally posted by Aspire: How about these. They have an offset that will allow them to fit on the inside but you will probably have to crazy with the fender rolling.
some of those r pretty nice. but the offset is too damn low. thats the look that euros like. wide and stretch the hell out of the tire. the backside of the wheel would have to be milled away to raise the offset on those. the kt4 is really sweet
Hugo AIM:omegazodiac
Posts: 80 |
thank you for the advices...I'll continue my search. But i search more for Ã?Âluxury wheels....and the one I fund was the Zenetti Flow in black....you can see them on the middle of this page: http://www.pdkwheels.com/zenetti.html so thank you anyway
Posts: 2,974 |
Nice wheels, I'm interested to see what they look like on the car ![](/ubbthreads/images/graemlins/cool.gif) . Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Posts: 728 |
I think the offset is the most important factor -- I'm rollin 18x7.5's (45mm offset and 225/40/18 tires) on one of the CSVT's with zero rubbing and had to buy some H&R spacers to get my 19x8's (40mm offset with 235/35/19 tires)to clear the struts and whatnot when turning on the Cougar.. I'm going to attempt to mount them onto my CSVT one day when I get bored, but I anticipate that I will rub as well without a spacer.
Crispy
99 Cougar - Arancio Atlas/Grey Graphite Pearl Custom Widebody
98 CSVT - Silver Frost #4014/6535 - Born 10/21/97
98 CSVT - Silver Frost #4085/6535 - Born 11/10/97
See My Rides
Posts: 4,639 |
Originally posted by NVMYSVT: I think the offset is the most important factor -- I'm rollin 18x7.5's (45mm offset and 225/40/18 tires) on one of the CSVT's with zero rubbing and had to buy some H&R spacers to get my 19x8's (40mm offset with 235/35/19 tires)to clear the struts and whatnot when turning on the Cougar.. I'm going to attempt to mount them onto my CSVT one day when I get bored, but I anticipate that I will rub as well without a spacer.
thats good to know. i'm looking at a wheel now 18x7.5 42et and i want 225/40. some guys with this wheel brand have rubbed occasionally. maybe having a shop mill the wheel to a 45et would get rid of the rub. but i'll drive on them first and look for rubbing.
nv, so does the cougar rub on the fenders? 8" wide 40et with spacers is basically lowering the offset. 5mm spacers and the wheel effectively has a 35et. just on paper if i was shopping for an 8" 35et i'd expect it to rub like crazy on the fender side. with a 19" i wouldnt want to run less than 235/35, which you r.
Posts: 4,639 |
Originally posted by BaggedContour: thank you for the advices...I'll continue my search. But i search more for Ã?Âluxury wheels....and the one I fund was the Zenetti Flow in black....you can see them on the middle of this page: http://www.pdkwheels.com/zenetti.html
so thank you anyway
check out kmc wheels. i've seen a few different kmc models on tours and they do some blingy wheels (what people call luxury)
Posts: 728 |
Originally posted by hmouta: Originally posted by NVMYSVT: I think the offset is the most important factor -- I'm rollin 18x7.5's (45mm offset and 225/40/18 tires) on one of the CSVT's with zero rubbing and had to buy some H&R spacers to get my 19x8's (40mm offset with 235/35/19 tires)to clear the struts and whatnot when turning on the Cougar.. I'm going to attempt to mount them onto my CSVT one day when I get bored, but I anticipate that I will rub as well without a spacer.
for the CSVT with the 18's I also want to note that I did take a hammer and pound the hell outta that rear lip thingy that sticks out.. Zero rubbing and I'm also runnin GC's and ST200 struts. I was really worried and did alot of homework before.. I kept seeing everyone rubbing so you have no clue as to how damned happy I was when I installed and drove around -- Ive currently gotten about 2000 miles on them without any problems.
As far as the Coug I'm not 100% sure that I can be a good reference as we made custom 1 off flares and I got the wheels and the spacers to fill the flares intentionally. Unfortunately when I did install when received (did not have the spacers at the time) I basically burned a channel into my brand new sponsored KDW's from the D ring on the CG's... there is only a few mm's of clearance with the strut and the tire -- I opted to go 15mm spacers in front and 30mm spacers in back -- I still rub a bit when I hit a bumpy patch of road and cannot slam the car due to being wider than my clearance and have already cracked 2 rear flares when the tires smacked up and made contact with the fender.. same with rubbing -- however I don't really rub on the struts anymore with the spacers.
I hope I answered your questions completely, if not let me know and I'll give it a go again ![](/ubbthreads/images/graemlins/smile.gif)
Crispy
See My Rides
Posts: 80 |
yeah it's in the brands that I was looking for too.....thanks!
