Page 3 of 3 1 2 3
another site for a similar problem said to put a new MLP sensor in//can u help? here is THEIR message..i need to call my mechanic today and talk to him i want to tell him what i have been told it can be,]
have a 95 ford contour automatic-transmission that seems to be slipping gears. I can be driving it and it acts fine, but then around 60-75 miles per hour it acts as if you were driving a manual transmission and were keeping your foot on the gas while pushing in the clutch and then dropping the clutch - causing a jerking motion. When my car does this, it will act as if it pops out of gear into neutral and then jerks back into gear. It will do this a couple times simultaneously and then be fine for a month or two and then do it again. I have taken it to the local ford dealer and they have had it for 2 1/2 weeks trying to duplicate the problem and get it figured out. I am getting impatient with them because they are a dealer, they should be able to figure this kind of thing out after having the car in there for the third time in a month and them having it now for 2 1/2 weeks on the third try. When the car "pops out of gear" if you still have your foot on the gas and go to accelerate, it will act like you are trying to accelerate in neutral. I don't think it is the engine, but I do think it is electronic - which the ford dealer does not. I believe that it is something in the computer that is telling the torque converter in the transmission to shift when it doesn't need to shift. Am I on the right track? Does anyone have any suggestions as to what it could be to help me out?
swhich01
View Public Profile
Send a private message to swhich01
Find More Posts by swhich01
10-02-2005, 11:35 AM #2
abruzzese
AF Newbie
Posts: 2 I am experiencing the exact same problem. Have you had any luck identifying the cause?? It is very fustrating.
abruzzese
View Public Profile
Send a private message to abruzzese
Find More Posts by abruzzese
10-02-2005, 01:04 PM #3
beyondloadedSE
AF Enthusiast
Posts: 1,287 Vehicle Speed Sensor.
__________________
1996 Ford Contour SE
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
Contour Enthusiasts Group
beyondloadedSE
View Public Profile
Send a private message to beyondloadedSE
Send email to beyondloadedSE
Find More Posts by beyondloadedSE
10-03-2005, 11:31 AM #4
swhich01
AF Newbie
Posts: 3 Re: transmission or something else?
I have not had any luck identifying the problem. It is very frustrating, I agree. If you have any luck, let me know.
swhich01
View Public Profile
10-03-2005, 01:06 PM #5
abruzzese
AF Newbie
Posts: 2 I can tell you for certain that it is not the engine itself. I unfortunatly had this occur for several months and had to replace the engine in that time frame. The issue still occures with the replacement engine. I am going to try the speed sensor that was suggested.
abruzzese
View Public Profile
10-03-2005, 01:15 PM #6
swhich01
AF Newbie
Posts: 3 Re: Re: transmission or something else?
The ford dealer that I am working with finally got my car to duplicate the problem and it is the MLP sensor. Hope this helps you out.
swhich01
View Public Profile
10-03-2005, 03:39 PM #7
beyondloadedSE
AF Enthusiast
Posts: 1,287 For future referece for the MLPS.
sfemme24,
Does yours appear to be in two gears at the same time (or shifting between gears at the same time)? If it is, then yes, it could be the MLPS (assuming you have an Auto).
Edit. Did you try changing the ATFluid first?
MLPS change.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1040336&page=&view=&sb=5&o=&fpart=1&vc=1
The tranny shift lever cable is below the car.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1116780&Forum=trouble&Words=shift%20lever&Match=And&Searchpage=0&Limit=25&Old=3months&Main=1116416&Search=true#Post1116780
and from Autozone.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/d3/97/0900823d801bd397.jsp
i cant explain how it feels but it doesnt ONLY do it when i go fast it does it alot of different times, dont know how to explain other than when i accelerat it jerks an then if i put foot all the way down on gas it wont go then let up and it jerks again, its sooo annoying, and when im low on gas, it just dies and it will start up again after a few seconds though i havent done anything w fluid except add that fuel cleaning stuff to the gas tank..does no good
i just cheked a reply on here and soeone said they replaced the atf fluid and it did no good
why did u send me links to cupholders and stuff?
Originally posted by sfemme24:
.. and when im low on gas, it just dies and it will start up again after a few seconds though i havent done anything w fluid except add that fuel cleaning stuff to the gas tank..does no good
Sounds like a bad fuel pump.
As for the tranny fluid change, if it is low (lower than minimum) or high (overfilled) or dirty now, changing it would help.
The other link (cupholders) refers to the cable (to the MLPS) beneath the car.
i told u i just spent $500 on a brand new fuel pump it did no good
Page 3 of 3 1 2 3
