Posts: 4,140 |
Why in the world would you want more tire pressure on the tires with less weight on them? The lightly loaded rear end should usually be significantly less than the heavy front if you're going for maximum stick.
Posts: 30 |
For street use i run 35 psi all around. I have stock suspension.
For track use i am going to crank the fronts way up and leave the rears about where they are at.
Brandon
1998 Black SVT Contour
born on 06/19/1997 # 2195 of 6535
1993 Black Escort GT *******(For Sale!!!!)********
1988 Black Escort RS **RIP**
http://www.myspace.com/soundman22
Posts: 3,637 |
ran 36 up front 42 out back, rolled a bit on the sidewall on the rears and a bit on the fronts, coulda pumped the backs up to 45 and the fronts to 39-40ish
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 710 |
That sounds like you were running rear tires with a very soft sidewall.
morbid
2000 Contour SVT (black)
Posts: 4,140 |
That's odd that you would roll them over. I suspect you were just getting positive camber due to body roll, if you're stock. I don't roll at all at around 30-34 psi. Having the rears softer lets me run all sorts of rear stiffness and keep the rear end from being tail-happy. I'd much rather have more grip and less rotation than the other way around. Rotation feels good, but grip is faster.
Posts: 3,637 |
Originally posted by Auto-X Fil: That's odd that you would roll them over. I suspect you were just getting positive camber due to body roll, if you're stock. I don't roll at all at around 30-34 psi. Having the rears softer lets me run all sorts of rear stiffness and keep the rear end from being tail-happy. I'd much rather have more grip and less rotation than the other way around. Rotation feels good, but grip is faster.
Im stock suspension less SBC
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 4,140 |
SBC?
Even stock, the Contour needs lower pressures in the rear. What tires were you on?
Posts: 3,637 |
BFG KDW 215/50/R16
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 44 |
After reading this post I put my fronts up to 38 psi for street driving and noticed a huge improvement. I was running 32 front and 28 rear and now 38 front and 32 rear. Awesome improvement in handling and much better grip from stand still. I wasn't sure whether it was advisable to run with higher pressure before I read this otherwise I would have done this sooner. Tires Dunlop direzza 215/50/16 on stock svt rims and stock suspension.
00 Silver Frost CSVT
#1136/2150 Born 4 Jan, 2000
Posts: 3,637 |
Originally posted by SD_zac: After reading this post I put my fronts up to 38 psi for street driving and noticed a huge improvement. I was running 32 front and 28 rear and now 38 front and 32 rear. Awesome improvement in handling and much better grip from stand still. I wasn't sure whether it was advisable to run with higher pressure before I read this otherwise I would have done this sooner. Tires Dunlop direzza 215/50/16 on stock svt rims and stock suspension.
Put more in the rears, like 38ish and you'll find a world of better handling
230.2 WHP @ 6500
237.0 WTR @ 2250
