Page 3 of 3 1 2 3
ok, i just assumed that big black amp was the stock amp, cause it looked like one. it's actually a rockford fosgate, that was powering the speakers, so now i'm worried that the speakers won't work, cause they were running through that amp and those crossover things.
2003 Dodge SRT-4 Mods: more than 250 characters worth!
first make sure your speaker work. use a AA battery and test them from the amp.
once your sure the speaker are OK use a multimeter and check if you got juice from the BAT. wire on each amps.
Turn on your radio and check if you got juice on each REM wire.
Doublecheck all your ground to see if they're not loose or broken.
Check the fuse on each amp + your BAT wire (under the hood)
If all this work... maybe your HU preout are dead...
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 - RU-3530/CTA Intake Pipe MSDS Heaser/Y-Pipe Magnaflow #10435 9mm Ford racing SPEC Stage one/Spec Alum. Flywheel HERE
Page 3 of 3 1 2 3
Moderated by  dnewma04_dup1
