Page 2 of 3 1 2 3
#1585568 06/07/06 01:25 PM
well as for my fuse box it has been under the battery for over a year now. no problems. as for if it is gmk intake? i have no idea, i bought this used from the classifieds. as for the blue hose it does not rub the water pump belt at all. once i get a new imrc box i am going to relocate it and put the cover back on just to hide where it was and then i will have the hose back like it is to be. as far as my spark plug wires, they are crap! they are numberd and are matched up to the right plugs it is just that one does not fit right! i am going to get taylor made thunder 8.2mm wires. good bad?? the filter i am using is the ru 3530! did not fit right however, went to trader horn and got a 3 in rubber hose. i cut a bout 2 in off of it and put inside the filter just enough to fiit when the clamp is at. when the clamp is tight it does not move!!! goonz, the bottom of the filter sits right at the inner fender wheel bottom. ( stock se inner fender) will try and get pics later today. as far as the hole where it goes though at, i used a beer cooler. the foam type. fit the intake tube nie and when in the hole perfect. and it is the same blue as the couplers are.i think that was all of the questions.. i think i am goin to try and put the fuse box bak on top just to see if it will fit there.lets hope for the sake i have to change a fuse.
G/f's black 99se sport 5 speed 2 1/2 test pipe-custom cat back 3 single tip cai with kn3530 safc optimized tb 8mm plug wires spec stage 1 clutch svt front bumper
#1585569 06/07/06 01:34 PM
Unless you plan on changing the blue hoses with a longer one, that is not going to fit under the cover. The cover pulls the hose into the corner then to the left to connect to the pipe. So either no cover, or longer hose.
The plug wires may be numbered wrong on that brand. Looks like you have too much slack on a couple of them and no slack on the other. Take out the front three and change around the order.
#1585570 06/07/06 01:55 PM
Originally posted by SVT4STD:
That hose is not going to last too long sitting right above the water pump belt.
What's up with your plug wires? Did you just pick any random way they would connect without checking the lengths?
+1
Originally posted by MxRacer:
Originally posted by RawBurt:
much like your weiner.
#1585571 06/07/06 07:05 PM
it does fit that hose is just long enough. i went out with the cover and double checkd.
#1585572 06/07/06 07:15 PM
I want a CAI
lol its a pita to put in and u will DEF. lose that ram air noise, this will be more subtle
#1585573 06/07/06 07:17 PM
Wow, it must be pretty damn tight. Or maybe my eyes are just not seeing it right.
#1585574 06/07/06 07:20 PM
I want a CAI
yes you loose that nice loud whoosh!... i can hear it still with my window down when i get on it. here is a pic i just took today.
these where taken at Mconnels mill state park.
#1585575 06/07/06 07:22 PM
there is just enought. if i would have trimed off 1 more inch, it would have kinked and not fit at all. it is that close.
#1585576 06/07/06 07:45 PM
you can hear mine when i lightly tap the gas as it sucks in air, its awesome..
#1585577 06/07/06 08:33 PM
Nice freaking pix!!!!!!!!1
Page 2 of 3 1 2 3
