F
F
I have a 98 svt contour runing great till my second intakes dont open up and have lost power i had this problem before and i replaced an o2 sensor and its fixed the problem but only lasted for a good 2 days..wow..Any suggestions i had replaced the imrc already still didnt do anything..Any help please???..
Thanks. Joe
Double Check That You Secondary Link Rod Hasn't Fallen Out Of The Linkage. Those Little White Plastic "pop-fittings" See A Lot Of Heat And Disintegrate. If That Is Indeed The Problem All The Pieces Can Be Had Through Ford For Around 20 Greenbacks.
Is The CEL On For Any Codes? If So, Get The Code Pulled And We Can Go From There. Auto Zone Is Free For This Service. Just Be Sure To Write The Actual Code Down And Don't Listen To Anything The $7.00/Hr. Employee Tells You.
Disclaimer: I, In No Way, Mean To Bring Embarrassment Upon, Criticize, Or Make Light Of Anyone That Works For Minimum Wage Or Wages Thereabouts...Other Than Autozone Employees, Because They Lack The General Knowledge Of Alphabet And Those Things We Call Numbers.
CSVT E0 3L 14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
F
F
Yeah all links are in tact i just reset the Pcm i dont know how long this is going to hold for i had a check on the car once..
List of codes that came up.
1.po155
2.p1151
2.p1519
You probably have gunnked secondary plates.. last time you rebuilt the UIM/LIM?
running at the correction limit probably caked on that crap, and now you have a non-operational IMRC.
Double check your IMRC bushing.. copper rod, and cabling..
As a resort, remove the IMRC cable from the secondaries (the hinged spring loaded connection on the LIM) and rev the car via the TB to see if the cable retracts with no resistance.. If so.. Clean your UIM/LIM by removeing it and rebuilding it.
If no movement is found, then look in to repairing, or replacing your IMRC (as long as you can verify that you have a correct voltage signal AT the IMRC, too..)
