Posts: 3,570 |
Originally posted by Icefury: I have a trans dapt kit installed. This kit required cutting about an inch off the block oil filter nipple as the adapter for the block bottomed out. So be forwarned the TD kit is not exactly plug and play.
Are we talking about the same kit? Mine IS plug and play, I didn't have to cut anything. Unscrew stock filter, screw on adapter, run hoses, wham, bam, thankyou mam.
Posts: 3,570 |
Originally posted by dpa43:
Originally posted by rkneeshaw3.0: Summit Racing is where I ordered mine from. It was on back order, and took a few weeks, but I did finally get it
Do you still have the part # for it?
Thanks Guys!!!
Had to work to find it, it doesnt come up by browsing:
FMS-M-6881-A54
Plug that in the search and it will come up. Runs about $78
Posts: 55 |
Originally posted by rkneeshaw3.0: Originally posted by Icefury: I have a trans dapt kit installed. This kit required cutting about an inch off the block oil filter nipple as the adapter for the block bottomed out. So be forwarned the TD kit is not exactly plug and play.
In the not too distant past, Trans Dapt had two molds of the block adapter and Mold 1 was a perfect fit. TD no longer makes Mold 1. You must have had a Mold 1 design.
Mold 2 will work but is alot more shallow so it required cutting down the block oil filter nipple about an inch.
2000 CSVT Frost Silver 3.0 Hybrid
Posts: 1,336 |
Don't forget to torque down the mounting boss when you remove it to cut it down if you have to ... 60 lb/ft. IIRC. and takes a 12mm hex adapter IIRC as well.
Posts: 710 |
The FRP adaptor is actually a common brand product, with their name on it. If I remember when I get home, I'll look at the instruction sheet... which says the actual company.
morbid
2000 Contour SVT (black)
Posts: 1,978 |
I cannot stress enough if your going to buy the kit, ditch the rubber hoses and buy steel braided! Trust me on this...
Meh, Ive had the kit for a little while now with the rubber lines, with no issues. Considering the prices of aeroquip fittings and such, it would double the price of the oil filter relocation. So far the only person I know with the stainless lines are dion (who loves them). Does that mean that everyone else (me, todd, ryan, etc...) are wrong to use the rubber....
Alex
'99 SVT Contour
Posts: 3,570 |
Originally posted by morbid: The FRP adaptor is actually a common brand product, with their name on it. If I remember when I get home, I'll look at the instruction sheet... which says the actual company.
Perma-cool I think
Posts: 21,197 |
You're mom is Perma Cool.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 21,197 |
BTW- What do you think is under the stainless braiding? RUBBER! All the braid does is help prevent rubbing. All external oil lines for aftermarket coolers etc should be changed every 12 months.
-'96 SE MTX 3L
Posts: 5,600 |
Most braided lines have a pretty high heat tolerance as well. Better than plain rubber.
It would easily double to triple the price of the relocation to do braided. I bought 3 ft. of braided line and some fittings for each end, and it was way over $50. I think just the 3 ft. of hose was that much, then figure about $5-10 a pop for each fitting, of which you will need at least 4 to change everything from AN to standard or metric thread sizes (for ONE hose). It adds up quickly. Though if you have the money. . . . .
Black 1998.5 CSVT
