Posts: 536 |
Originally posted by Bk4293: But Dan, it's the same part #.......
I believe the exhaust manifolds are the same on all Zetecs, just different where they connect to the cats (flanges).
notice i didnt mention the gasket as i am aware that its the same one. i simply stated that the intercooler plumbing might have to be modified if a kit even exists.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 22 |
ok if they are the same on all zetecs, why does the focus manifold gasket is not the same?
Posts: 1,367 |
Are you really trying to imply that that having the same "gasket" will imply a turbo will fit? Or was I translating your South Americanese wrong?
It doesn't mean anything.
Sal Khan
00 SVT - Not pretty
00 Aprilia RSV Mille - Also Loved.
http://www.thelunchjournals.com
"I just want someone I can stand once her mouth is free of obstruction."
Posts: 495 |
The Focus exhaust manifold is very different from the contour manifold. They do have the same bolt pattern so technically, you could use one, but I wouldn't. My dad has a Focus and I've seen both our gaskets and the Cougar/Contour gasket is 3 times thicker than his. It just looks more solid.
Also while you could bolt a turbo to a Focus manifold, I'd be tough because the Focus doesn't have a front engine mount near the radiator so getting the turbo inlet pipes to clear it would be tough. If you could get the Focus manifold to work, then I'd use that gasket. Otherwise stick with the gasket for your car.
2000 Rio Red I4 Cougar
200whp & 210wtq at 9psi
254whp & 276wtq with NX 35shot
WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
Posts: 22 |
so you are saying the focus manifold will bolt up yo the contour.because i'm thinking since noone makes a turbo kit for the escort zx2,i'm wondering what about the focus, what mod i got to do to make it fix
CEG road warrior
CEG road warrior
Posts: 17,248 |
Focus mani should work fine. I have done some research in the past.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 536 |
if your looking to get a manifold done check out these guys. the ZX2 one should work just fine and then you can get whatever turbo flange you want and can locate it wherever you want on the manifold. JGS click on the header kitsw link. pretty good prices too.
97 contour gl mtx
19mm bat sway bar
Posts: 702 |
Originally posted by ford zetec2: so you are saying the focus manifold will bolt up yo the contour.because i'm thinking since noone makes a turbo kit for the escort zx2,i'm wondering what about the focus, what mod i got to do to make it fix
GUDE Makes A Kit For the ZX2 And I Believe Tom's Turbos Does As Well. Tom's In N.C. If I Remember Correctly.
CSVT E0 3L
14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
Posts: 179 |
Use a kit for a focus and just modify the FMIC piping. A vortech FMU will work for the fuel enrichment if you have a return style fuel system. I am sure there might be some small mods to everything that will have to happen, but The ZETEC engine is the SAME from a mounting a turbo to it standpoint. HENRY
95 Contour, Custom EVO bodykit, 2.0l, PNP Focus head, Stage 2 cams, Je pistons, Eagle rods, 4in1header, 2.5" header back exhaust(complete stainless), D P nitrous, ram air intake, 10mm wires, flamethrower.
