#1584006 06/04/06 08:59 PM
Hello
We have a 98 with a Zetec in it. The car has 155000km on it . The water pump has never been changed . We have a 4500km trip this summer .Do you think i should change it before we go? It is working okay right now . How do you check it ? Thanks again
Unfortunately, you can't really inspect the water pump without taking it out. If you decide to go through the trouble of taking it out, then you might as well change the water pump. A broken water pump can cause overheating and head gasket issues. If you are concerned, you should change it before the trip.
From 1996 Ford CD Manual,
Water Pump 2.0 liters
SPECIAL SERVICE TOOL(S) REQUIRED
Camshaft Alignment Timing Tool T94P-6256-CH
Camshaft Sprocket Holding Tool T74P-6256-B
SPECIAL SERVICE TOOLS DESIRED
D85L-6000-A Strap Wrench
Removal
1. Disconnect negative battery cable.
2. Raise vehicle on hoist.
3. Remove right front wheel assembly.
4. Remove crankshaft pulley shield retaining screws and shield.
5. Remove drive belt.
6. Using Strap Wrench D85L-6000-A to prevent engine from rotating, remove crankshaft pulley bolt and pulley.
7. Remove lower timing belt cover bolts.
8. Remove front splash shield retainers and shield.
9. Partially lower vehicle.
10. Drain the engine cooling system.
11. Tighten drain petcock.
12. Lower vehicle.
13. Remove two engine intake air resonator nuts and bolt, loosen the hose clamp at inlet tube, disconnect sensor, and remove intake air resonator.
14. Loosen coolant reservoir hose clamps. Disconnect hoses and position aside.
15. Remove two screws retaining coolant reservoir to the inner fender and one screw retaining hose locator to inner fender. Remove reservoir.
16. CAUTION: Position a block of wood between oil pan and floor jack.
Position a floor jack under oil pan and slightly raise it to release pressure from front insulator.
17. Note: Make a reference mark to aid during installation.
Remove six front engine support insulator bracket nuts and bracket.
18. Remove three front insulator bolts and insulator.
19. Remove power steering reservoir line nut and two bolts retaining the pump line at engine lifting eye and steering pump bracket.
20. Remove oil level indicator, three exhaust heat shield bolts, and air conditioning hose bracket nut. Position bracket aside. Remove heat shield stud and shield.
21. Remove four power steering pump bolts. Position and secure pump assembly aside.
22. Disconnect the lower radiator hose at water pump and position it aside.
23. Disconnect ignition wires from spark plugs and position them aside. Remove 8 mm upper timing belt cover bolts and upper timing belt cover. Remove 10 mm valve cover bolts and valve cover. Discard gasket.
24. Remove idler pulley bolt and pulley.
25. Remove water pump pulley bolts and pulley.
26. Remove center timing belt cover bolts, center cover, and lower cover.
27. Using Camshaft Alignment Tool T94P-6256-CH and Camshaft Sprocket Holding Tool T74P-6256-B, align the camshafts by installing tool into the slots at the rear of camshafts.
28. Note: If the timing belt is to be reused, mark the direction of the belt to aid during installation.
Remove timing belt tensioner bolt, tensioner and belt.
29. Remove four water pump bolts and water pump.
30. Clean the water pump-to-engine mounting surface.
Installation
1. Position water pump and install bolts. Tighten bolts to 15-20 N-m (12-15 lb-ft).
2. Loosely install timing belt tensioner, bolt, and belt. Adjust belt tension. Tighten bolt to 35-40 N-m (26-30 lb-ft).
3. Position lower timing belt cover. Install center cover and bolts. Tighten bolts to 6-8 N-m (53-71 lb-in).
4. Position water pump pulley and securely install bolts.
5. Install idler pulley assembly and tighten bolts to 48 N-m (35 lb-ft).
6. Remove camshaft alignment tool.
7. Using a new gasket, position valve cover and install bolts. Initially tighten all bolts to 2 N-m (18 lb-in) and then tighten them to 6-8 N-m (53-71 lb-in). Connect spark plug wires.
8. Position upper timing belt cover and install bolts. Tighten bolts to 3-5 N-m (27-44 lb-in).
9. Connect lower radiator hose to the water pump.
10. Position power steering pump assembly to bracket and install four power steering pump bolts. Tighten bolts to 25 N-m (18 lb-ft).
11. Position front insulator and power steering hose bracket. Install three bolts and tighten them to 70-95 N-m (52-70 lb-ft).
12. Position front engine support bracket and install six nuts. Tighten nuts to 70-95 N-m (52-70 lb-ft).
13. Remove the floor jack.
14. Position coolant reservoir. Securely install two reservoir screws and one coolant hose locator screw to inner fender.
15. Connect coolant reservoir hoses.
16. Position exhaust heat shield, coolant tube, and hose retainers. Install three heat shield bolts and one stud. Tighten retainers to 8-11 N-m (71-97 lb-in). Position A/C hose bracket to stud, securely install nut and install oil level indicator.
17. Install power steering reservoir line nut and two bolts retaining pump line at engine lifting eye and steering pump bracket. Tighten retainers to 6 N-m (53 lb-in).
18. Position engine intake air resonator. Securely install one bolt and two nuts. Connect the sensor and securely tighten hose clamp to the inlet tube.
19. Raise the vehicle.
20. Install lower timing belt cover bolts and tighten to 6-8 N-m (53-71 lb-in).
21. Using Strap Wrench D85L-6000-A to prevent the engine from rotating, install crankshaft pulley and bolt. Tighten bolt to 110-120 N-m (81-89 lb-ft).
22. Install drive belt.
23. Position crankshaft pulley shield and securely install screws.
24. Position front splash shield and securely install screws.
25. Install right front wheel assembly. Tighten wheel nuts to 85 N-m (62 lb-ft).
26. Lower vehicle.
27. Connect battery ground cable
28. Fill engine cooling system, start engine, and check for coolant leaks.
And from Autozone
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/c4/af/0900823d801bc4af.jsp
If you are doing it yourself, you might as well throw in a new timing belt. If you have a shop do it for you, they will probably suggest putting in a new timing belt as they will have to go through the process of installing the belt anyway.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1230939&Forum=trouble&Words=jd28&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=1230126&Search=true#Post1230939
#1584008 06/05/06 02:42 AM
when was your timing belt replaced? They usualy need to be replaced every 90K miles... and the water pump is in fact located in the same area as the timing belt, most people around here replace the water pump while the belt is being replaced.
