Posts: 504 |
Originally posted by SVTCJ:
This is the exact same problem I had with my Trubenz exhaust. The passenger side stuck out a good 2" farther than the driver side.
I ended up paying a muffler shop $50 to cut and reweld the passenger tip so it was the same as the driver.
i have the same problem as you and tourige. mine is probably 2" off like yours. the guy that put mine on tried moving the hanger but since the rubber moves it just went back to where it wanted to be. is cutting and rewelding the only option? or is it just cheaper and easier than bending the pipes after they split? (did they do the cutting while it was on the car or did you have to take it off yourself and bring it in?) the exhaust sounds awesome but looks horrid when its uneven. fixing this would make me very happy (im not worry about spending a few $'s btw)
- 98 SVT #5999 -.
-CDA-7894 w/ ipod interface
-Knauberized, Trubendz 2.5/highflow cat
Posts: 853 |
hmm.. thinking twice about getting a trubenz system. I thought most people were happy with the trubenz system they got.
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 503 |
This is a little late but if it helps at after I cracked my oil pan 2 years ago (don't ask) I put some JB Weld on 2 inch crack on the inside after cleaning it up and havn't had any trouble since. Put on about 20,000 miles and thats driving in -30 in MN and 95+ in Florida this summer, so its seen its share of shrinking and expanding.
95 LX-with a mind of its own
24v DOHC
SVT exhaust and K&N=all thats worth modding
Go Fighting Sioux!!!
Posts: 6,106 |
Should have went Bassani!!  5 years and zero leaks.  Mark
2000 Black CSVT
Posts: 1,746 |
Originally posted by BlackE1: hmm.. thinking twice about getting a trubenz system. I thought most people were happy with the trubenz system they got.
I am perfectly happy with mine. I think most people are happy with their system, it's just that you usually only hear about the bad ones because those are the owners who need to fix something. And in all honesty, something as small as a hanger needing to be bent over an inch, or a pipe fitting too loose inside another are hardly worth noting as they are literally 5 minute fixes.
2000 Contour SVT
SF - #542 of 2150
Posts: 21,197 |
Originally posted by lizard: then shut up and do it the wrong way and then spend twice as much money later down the road. why did you ask if you knew you were gonna have to spend money, think about it who would agree to doing something half assed
LMAO! Hit it on the head. And by Adam no less.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 587 |
My exhaust setup didn�t fit to my liking, went to a shop and got it aligned. It cost $40, I sent Trubendz an email about it. Making a long story short, I sent a scanned copy of the receipt and get $40 off another part from Trubendz. I still haven't needed another part though.
3L process done
Posts: 21 |
$10-20 a weld with 5 welds is a complete rip off. If you brought it to me, I would have welded the thing for you for $30, assuming you took it off your car. Like what was said above, take it to a shop that isnt ran by a bunch of crooks. As far as JB weld. No more cutting corners with your car. There is a difference between not having enough, then waiting to do something, and just plain going ghetto style to save a buck.
Eloy
Smoothlinez Auto Salon
