Posts: 1,225 |
I have a question. Will a Zex system work with the SAFC reconfigured. And will it be too rich if I am WOT with no nitrous?
"Speak English... I am speaking Engrish..."
Steve Chang
99 Silver SVT Contour #196 (Garaged)
06 Dark Blue Pearl Fusion SE V6 (Daily)
05 Dark Shadow Grey Freestyle Limited AWD
Posts: 5,810 |
From what I can tell, Zex will only allow the fuel pressure to rise when you have the system on otherwise it will let the regulator run normally.
The SAFC should not interfere with the zex as it is a maf scaling device and that indirectly affects the injector duty cycle instead of fuel pressure. So bottom line, an SAFC that is used to fine tune your AFRatio on the car will be operating the same way even with the zex system on or off.
See My Mods
Posts: 5,810 |
Oh, if you mean can you use an SAFC to add WOT fuel for nitrous instead of the normal setup zex uses? Probably NOT. Not without some creative add-on components.
See My Mods
Posts: 1,225 |
Thanks, thats what I needed to know.
Steve Chang
