Posts: 536 |
do you use the defrost. if so then you might consider keeping it. the defrost uses the ac to dry the air.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 10,015 |
Originally posted by amarv12: You can get one that looks like this :
Get the one labeled for Fords ...you can see it has 4 openings for 4 different sizes of connectors. You close the opening onto the pipe and push the flared end into the connector, then pull the connector off.
The one tool will work on the AC connector and the fuel lines.
Should be a couple of bucks, $5 or so.
I have that and it didn't work. I use a hacksaw instead.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 21,653 |
Originally posted by Auto-X Fil: 40+ lbs off the front end of a car that's already front heavy is huge.
My condensor, compressor, accumulator, and most of the lines only weighed 24lb.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 4,140 |
Hmm, sad story. How much freon is in the system? That has real weight. What about the evaporator, too?
Posts: 536 |
Originally posted by Auto-X Fil: Hmm, sad story. How much freon is in the system? That has real weight. What about the evaporator, too?
you have at most three pounds of refrigerant (freon is a brand of r-12) in the system. evap cores only weigh a few pounds also.
97 contour gl mtx
19mm bat sway bar
Posts: 4,140 |
so more like 30lbs than 40lbs. That's surprising seeing how heavy the A/C is in many other cars. Very cool that Ford did a good job, but sad that I'm not going to lose that much weight.
Posts: 3,732 |
the metal tool dont work too well, the plastic ones work way better
Russell
Oval Port 3L Nearly Done
Posts: 9,065 |
Originally posted by Russell-3L: the metal tool dont work too well, the plastic ones work way better
Plastic tool FTW!
The metal one sucks!
Posts: 2,007 |
Works fine if you know how to use it.  It's slightly harder to grip due to the shape but if you press it up into the connector from both sides it works fine.
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 4,140 |
Now obviously I had a mechanic remove all refrigerant from the system, because that's the law. But, you always treat a gun as if it's loaded, right? So, assuming the mechanic messed up and didn't quite get all the refrigerant out, how would I proceed to open the system safely, in case there's *some* left in the system?
