You can get one that looks like this :
Get the one labeled for Fords ...you can see it has 4 openings for 4 different sizes of connectors. You close the opening onto the pipe and push the flared end into the connector, then pull the connector off.
The one tool will work on the AC connector and the fuel lines.
Should be a couple of bucks, $5 or so.
