#1582075 06/01/06 03:47 AM
codypka Offline OP
Just got my CSVT and I'm already running into problems. Every now and then, when decelerating with the clutch engaged, the engine just shuts off. It starts back no problem but its extememly annoying since i've done nothing to make the thing stall. It seems so happen 99% of the time when in 3rd or 4th gear and traveling downhill. my CSVT is completely stock with the standard MTX 2.5L Duratec
Could this be a fuel starvation problem, need new fuel pump or filter?
ANy help on the matter will be greatlty appreciated
2000 Contour SVT in Silver Frost #1633 of 2150 -17inch deep dish chrome rims -driller racing rotors -modified intake with open-air K&N filter ...TruBenz exhaust is next!
#1582076 06/01/06 03:54 AM
Welcome . How many miles? Check Engine light on? Scan it (free service at Autozone or Advance) and post the codes.
#1582077 06/01/06 05:00 AM
codypka Offline OP
it has 96000 miles. the check engine light comes on when the engine shuts off but is not on during normal driving
i've the term pulling codes thrown around here. could someone explain what this means? I can really get this done at autozone for free?
#1582078 06/01/06 05:04 AM
Yes, free "pulling" of Check Engine Light codes at Advance or Autozone (in the hopes that you will buy the parts from them). Get the exact code from them and post.
If you want to purchase one, code readers/scanners start from about $75 up.
#1582079 06/01/06 05:11 AM
Start by cleaning your throttle body and IAC (idle air control) valve. Very likely it is all you need.
#1582080 06/01/06 05:18 AM
codypka Offline OP
thanks for the info. however, i have very limited mechanical knowledge as far as where these things are located, what they look like, and how to actually clean them
if no one feels like explaining i understand cause it would prolly be painstaking. but is their maybe a thread already on here showing how to do this? i searched but couldnt find anything
thanks for all the help
#1582081 06/01/06 11:23 AM
Welcome...Check here This should help. If you dont see something you need try a search. Like you said some one will be able to help you or point you in the right direction.
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998 WR Headers GMK CAI Blaupunkt system fiberglass tweeter pods L.E.D. tail lights in the works
