Posts: 24 |
My passenger's headlamp are weaker then driver side headlamp, and I have check everything that need to be check, still can't find any problem on it. Dealer told me it is the ground wire going toward to the passanger headlamp. However, teamfordparts told me it was the headlamp switch that is weak or something. I have check all the fuse and everything, but it is good. Please, anyone tell me what's the problem I have. If you know, please do email me for this problem at dlchien@yahoo.com.Thanks David
Posts: 5,345 |
Did you try putting in a new bulb? Sometimes, halogen bulbs do lose their luminance after a few years.
If it is a ground wire problem, that should be a easy fix. Test by putting in a new ground wire and see if it improves.
Edit. From 1996 Ford CD manual.
PINPOINT TEST AD: RH LOW BEAM HEADLAMP INOPERATIVE
AD3 CHECK GROUND AT RH LOW BEAM BULB
Remove RH low beam bulb.
Using an ohmmeter measure resistance to ground in Circuit 31 (BK) from RH low beam bulb socket.
Is resistance less than 5 ohms?
Yes
REPLACE RH low beam headlamp bulb. RESTORE vehicle. RETEST system.
No
SERVICE Circuit 31 (BK) for open. RESTORE vehicle. RETEST system.
1996 V6 ATX 96K miles
Posts: 24 |
I did have try to change a new headlamp *silverstar*, but it turn out to be the same no different. so basicly I just need to get my ground wire to check up right?? cause I have the same feeling that the ground wire is bad. please let me know.
Thanks David
Posts: 5,345 |
Yes, check the ground wire for the passenger side headlamp.
Posts: 24 |
how do I find the ground wire for the passenger side head lamp?? just wonder. I try to look for it that day, i can not find it. please help me on this.
thanks David
Posts: 5,345 |
Originally posted by Tony2005: ....Using an ohmmeter measure resistance to ground in Circuit 31 (BK) from RH low beam bulb socket.....
You should start by cleaning the connector first just in case some dirt got in or it is rusted inside.
Assuming it is a ground fault,
Unplug the RH low beam bulb connector. Unwrap the wiring "external wrap". You should see a wire which is Black (BK) Circuit 31. You need to test it. If you don't want to or don't know how to, just splice another wire to this end and ground it.
If it was a ground fault, then, the headlamp should be (or close to) as bright as the other side.
Posts: 24 |
i did also check the connector is clean. wasn't there is like black, red, and white wire that connect to the connector? just wonder. when i test the connector it was good on the voltage when it turn on, but i just don't understand why it is so weak.
Posts: 5,345 |
Originally posted by Tony2005: .... You should see a wire which is Black ... You need to test it. If you don't want to or don't know how to, just splice another wire to this end and ground it...If it was a ground fault, then, the headlamp should be (or close to) as bright as the other side.
Posts: 74 |
i bad ground is very likley
Posts: 24 |
Thank ya for the help, it wasn't gound wire either. I have everything clean up and change another set of headlamp and now it work. thank ya for the help.
