Posts: 460 |
Jason,
I really dont think you have anything to be worried about on the Big Track. Just take it easy the first few laps, building up your speed each time around. I would say the only corner you need to really worry about is the last one, Turn 9. It is a decreasing radius turn and sneaks up on you, and will even get the best of them!!!
Nikolas
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Posts: 460 |
Here is the website that has info on the event: http://www.duratecperformance.com/Willow.htm Pass it around..... Nikolas
Posts: 1,038 |
any guesses as to how fast you think we can hit on the straight? i read you come out of turn 9 pretty hot, and the straight following it is a 1/2 mile long, so near 120??? that'd be neat to brag about -jason
Posts: 460 |
I think 120 will be easy to hit....if not 130.... Unless I get my speed limiter removed, I will be stuck at 115 down the front straight.. then it is hard on the brakes so you can do about 60 or so through turn one......
Nikolas
Posts: 2,906 |
that straight much be huge if you could hit 120. It takes awhile to get there.
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 460 |
The last turn coming onto the straight is a fast one, I would guess you will be able to maintain about 80mph around it or so, if not faster....then the straight is 1/2 mile long.. 120 is not out of the question....
Nikolas
Posts: 1,038 |
i read on one of the so cal boards a guy in an svt went into the dirt on turn 9 at 95. didn't sound like he was goin too fast. if you can come outta there around 90 i think 120 sounds fair. one way to find out -jason
Posts: 2,906 |
That must be one BIG A$$ turn coming in to the straight!
