Posts: 54 |
the only thing i found in the oil pan was metal shavings  the block has a build date of oct 02. I would like to know as well what years the sand issue was in. If i can find a taurus motor cheap i might just swap out the pan and cams. the escape cams seem to have more torque at the lower end wich fits my autox needs more, but i may be wrong in this though
Posts: 5,810 |
Well, I don't know about the new escape blocks but if you get one with a few miles on it and then go through it properly you will likely not have any problems.
BTW, sometimes these rods spin bearings....it has been happening on contours for years and has been known as the "oil starvation issue". So it isn't new, it isn't completely unexpected for one to pop up especially when you don't know the build details.
IMO if you buy duratec based contour or 3L adapted contour from someone and you don't know the public history of the the engine/car? Plan on taking the time to pull the pan and do a bearing inspection. THe worst it will cost you is a couple of hours and some new rod bolts that are easy enough to pop into the caps. If you are at it with a little time and energy and you mic the crank to find the diameters, you can install better quality clevite77 bearings for a little extra insurance.
At this point, post a picture of the damaged crank journal so we can see....just out of curiosity. One of us may be able to recommend a course of action based on how damaged it is.
See My Mods
Posts: 9,065 |
Originally posted by warmonger: Well, I don't know about the new escape blocks but if you get one with a few miles on it and then go through it properly you will likely not have any problems.
Oil starvation on a full oval port!? No way. I've cranked my engine to 6k on hard right handers and I've watched my oil pressure stay constant!
Posts: 21,197 |
Tell that to my last engine.
TH...
....well SOME of us have never subscribed to it as
being an oil starvation problem on ANY V6
Duratech...but then again the masses decide, right!LOL
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 9,065 |
Originally posted by todras: Tell that to my last engine.
Oil starvation how?! In 50 miles what happened todd?!
I think that was builder error...did you prime the engine before you started it up?!
Posts: 54 |
the last autox had 2 360* turns here's a pic of the damage, not the greatest however
Posts: 5,810 |
Well that certainly looks repairable. Maybe a sharper image will tell for certain.
See My Mods
Posts: 5,810 |
TH...
....well SOME of us have never subscribed to it as being an oil starvation problem on ANY V6 Duratech...but then again the masses decide, right!LOL
Actually Terry was one of the people that brought a lot of information on oil starvation to light in the beginning. He suggested the use of Accusumps, suggested the use of clevite77 bearings (a good one I might add )to give a bit more durability, and also suggested it might be crank whip and caused a mass movement to buy DMDs...that has now been retracted as apparently making no impact on spun bearings.
Since no one knows why for sure except that many people get oil light flashing minutes before the bearings go, it seems to have settled back to oil sloshing in the pan during sweeping turns as a likely cause.
See My Mods
