#1580978 05/30/06 03:38 PM
dgodard Offline OP
Hi guys, doing a visual inspection at engine bay, i looked this:
You can see how hood is kind of burned...
Now, the spark plug wires are loose, like this:
Checking other pics in forum car has missed 1 "L" shaped piece of plastic wire separator, can be this make wires to arche and burn under hood? Any inputs will be appreciated!!!
Thanks in advance
00 Mystique LS V6 ATX 57K miles K&N air filter TH Fix B&M 70268 Atx cooler
Originally posted by dgodard:
Checking other pics in forum car has missed 1 "L" shaped piece of plastic wire separator, can be this make wires to arche and burn under hood? ...
Could be. How old and how many miles on the SP wires? Have someone rev the car at night or in a dark garage, and see if there is arcing.
dgodard Offline OP
Thanks by replying Tony
I bougth car with 50kmiles on it, now it has 57kmiles....i guess these are original SP wires I'll do what you say at night too to see what happens or do you recommend me to replace SP wires?
Does anyone has the part number of the "L" shaped piece of plastic wire separator?
dgodard Offline OP
Hi again Tony, did it last night with hood open and semi open...and didn't notice any spark or arching from wires....could be that arching is only present when hood is very hot or something like that?
