Page 5 of 5 1 2 3 4 5
#1580701 06/06/06 03:49 PM
Originally posted by cvkillacontour98:
can someone describe a tapered plenum to me.
Tapered.. as in one end is smaller then the other end of the runner.
Depending on the plenum design it could be tapered too but the original tapered comment was about runners.
04 Subaru WRX "Eurosport bling bling fast and furious tokyo drift" "They have diarrhea of the mouth, and constipation of thought"
#1580702 06/06/06 09:22 PM
H
H
Tapered.. as in one end is smaller then the other end of the poop.
No, it's when the ends are smaller than the middle. Like poop.
-Auto Makor- -Experimentor -Station Wagonor- -Computerizor- I have a foot that is bigger than a foot. SuperChipFOR SALE
#1580703 06/07/06 12:25 AM
Sweet.. I'm gonna make a custom intake with poop shaped runners for my WRX.
#1580704 06/07/06 01:01 AM
Usually the runners are tappered from the plenum to the valves. This taper causes the air to compress inside and removes some of the air that has stopped along the runner wall.
That is not a very good description, so I will try to explain it better. The wall of the runner is not moving, so the air touching it can not move, or moves very slowly. The longer the runner the more air stacks up along the wall. If the runner is tappered the cross sectional area decreases making less space for that air to build up. The ideal taper is approximately 5% decrease in diameter per inch of runner length.
The ideal size of the plenum is 1.5 times the engine displacement. If it is any bigger than that you end up with a loss in throttle response. If it is much smaller you end up with uneven flow to the cylinders.
Hope that clears up the issue some.
1998 Contour SVT Black w/ Blue interior Torsen LSD updated shiftforks Lightened Flywheel, HD Drivelines Optimized Thottle Body 2003 3.0L engine upgrade (Soon to be)
