Posts: 1,238 |
Longer runners, ideal for FI. -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 10,015 |
Originally posted by tropictour: Longer runners, ideal for FI. -tropictour
Since when? For FI the SHORTER the better.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 137 |
Originally posted by Stazi: Originally posted by tropictour: Longer runners, ideal for FI. -tropictour
I have to agree this time.  The only time long runners are better is when you are trying to get some naturally aspirated Resonate Ram Tuning effect at lower RPM ranges. There are always piping losses that increase with increase length.
1998 Contour SVT Black w/ Blue interior
Torsen LSD updated shiftforks
Lightened Flywheel, HD Drivelines
Optimized Thottle Body
2003 3.0L engine upgrade (Soon to be)
Posts: 1,049 |
i heard that short runners is better for f.i. plus a decent sized plenum too. i heard the plenum should have half the capacity of the engines displacement. most of the realy high turbo powered cars ive seen use real short runners with a more aerodynamic manifold design. all of those 1000hp supras have a manifold similar to the skyline because the supras stock manifold is restrictive at a certain power range.
Posts: 1,210 |
St220's runners are tapered which is the main reason why it's superior
3.0 14.392@97.237 2.302 60ft
OEM 4-bolt LCA's $105 each
Watch me go
Posts: 1,049 |
Posts: 1,210 |
tapered plenums
Watch me go
Posts: 240 |
Originally posted by Stazi: 2) They have the habit of not lasting long <40,000mi
After four years of running a shop I never once saw an Expedition or Excursion or Lincoln or Mustang with COP that when one of the coils went, it didn't have anything less than six digits on the odometer.
Hell my Mazda6 was in this so called range of failure with an MSD Stacker 8-channel box supplying power (Something else you guys forgot about in this conversation) to them and they never failed once or even misfired.
Driving the Caliber
Side project: The LT-5 Fiero is being born..
Posts: 1,049 |
can someone describe a tapered plenum to me.
Posts: 9,065 |
Originally posted by cvkillacontour98: can someone describe a tapered plenum to me.
Well it's tappered for her pleasure!
