Posts: 124 |
Is it normal for headunits to start skipping if they get too hot? I am wondering if I need to do some sorta mod to add fans in there or something...or maybe return the head unit for another one...
98 Silver Frost CSVT
#415 of 6535
Born on 4/23/97
Weapon R Intake
B&M Short-Throw Shifter
Panasonic CQ-C9901U Head Unit
Indiglo Gauges from StreetRacerParts.com
{PM me if you want a pair of Pre-98 Sail Panels}
Posts: 785 |
if its still possible i will return it... no HU suppose to need mods to work properly
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 3,065 |
I have never had a head unit overheat. Even when running for 7/8 hours straight. The CDs come out a little toasty, but the player still works fine. Like mentioned above, try to return it, something is wrong with it.
Posts: 124 |
Alrighty, well I contacted the seller about the HU and he said I can send it in and he will exchange it. I jut hope that it doesn't take TOO long cuz this thing sounds amazing. The only reason that I thought of overheating is because this HU runs 70x4 watts...which is higher than most other HUs. I don't know too much about car audio components, which is why I came here to ask you guys. Thanks for the input.
#415 of 6535
Born on 4/23/97
Weapon R Intake
Posts: 1,882 |
What HU was it? Manufac./Model ??
Edit:  Never mind, I see it in your sig now. Duh me.
Posts: 299 |
Is it this one? Panasonic CQ-C9701U It's 31x4 rms if it is though.
98' Black SVT
Build #1915 of 6535
Posts: 1,882 |
Here it is: CQ-C9901U Still 31w RMS. 70 peak.
Posts: 299 |
one for me too...D'OH!
98' Black SVT
Build #1915 of 6535
Posts: 785 |
ive been running a alpine 60X4 since 6year without any overheating. but just one thing, dunno for the pana...
but i was thinking since most of 60X4 HU and over are often advise to pass a direct B+ to the battery or fusebox for operating fine, maybe that could cause overheating if not well powered....
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 124 |
Hmm...well it doesn't mention anything about that in the install directions or anything...I think I either have a bad unit or it got damaged when it got stuck in the dash bezel...  Basically one of the metal tabs on the bottom of the chassis got bent backwards and I had to cut it off to get it out again...dont ask...haha. Either way, I am going to send it back and get another one so hopefully the problem lies within the HU that I have now. And about the power, yeah the 70x4 wasn't referring to the rms, i was referring to peak. Which looking back on was kind of a stupid thing to say because the HU doesn't run that high constantly...oh well, I am still a noob on this stuff and I am not ashamed to admit it. That is what all you wonderfully knowledgeable people are for.
#415 of 6535
Born on 4/23/97
Weapon R Intake
