#1580475 05/29/06 09:54 PM
Hello
On the weekend i changed the coolant and thermastat on our 98 zetec.Today the A/c stopped blowing cold air . I was just wondering if it could be related ? or is is just a seperate problem .Thanks
#1580476 05/30/06 01:26 AM
Originally posted by jakerboy:
Hello
Most probably separate problem. Unless you accidentally bumped a switch loose. If it is only blowing air then check if there is enough refrigerant. Autozone or Advance sells the recharge kits with gauge for about $25.
