Posts: 203 |
I have been searching for over 30 minutes now, with no luck, trying to find the post on how to adjust the shift cables. I have my car jacked up and the drivers wheel off. Is there something that you push at the end of the cables to adjust them? TIA
Posts: 4,693 |
Jim Johnson
98 SVT
03 Escape Limited
Posts: 3,637 |
I tried doing this but my damn clips wouldent go in, so i just left it.. but i think i moveed something cause its REALLY hard to get into reverse now.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 702 |
There Is A Little More In Depth Conversation Here: Click Me For Shifter Adjustment Goodness
CSVT E0 3L
14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
Posts: 21,653 |
Thanks for the info and double thanks to SVTatGT for translating.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 203 |
I finally found my notes that I saved from a post. I had printed them out and couldn't find them. Not sure why this didn't come up during my searches though, but here it is.
"...be sure the levers on the trans are both vertical (neutral)position (drivers wheel off) Press in the orange spring plastic buttons on the shift cable from the cable ends. The stick must be dead vertical in the shifter and dead center between 3rd & 4th. You may find you need to move the stick towards 3rd postion (this is being done with the orange 'locks' in and disengaged. Press the tab on the side of the cable ends to unlock the orange button. It must pop out to lock the cable...it has a spring under it. Depress the clutch and see if you 'feel' the 2,4th gear engage before the stick touches the rear of the ally housing. If you have adjusted too much you will lose travel on 1st/3rd etc..Only adjust the WHITE cable end...that covers front to rear movement of the stick. The black cable end is side to side in the neutral part of the 'gate'."
"The shifter cable end you want to adjust is white with an orange button on it. It is the one closest to you once you get the wheel off and look up in there. Pushing the orange button releases the cable from the end and when it pops back out it locks on the cable again."
"Yes shifter in neutral. Dead Center. Push the orange button in, which releases the cable. Then make sure the shifter is still in dead center, I pushed it slightly up towards 3 to give me more rear travel. Then release the orange button and you should be good to go. If it's still not good try again, if you went too far same thing, just try again, it's real easy. You don't nessarily have to be driving to feel if you did it right. Once you lock the the cable back on go row thru the gears and see if you can get to all of them before lowering the car."
Posts: 3,637 |
Originally posted by Sivart: "Yes shifter in neutral. Dead Center. Push the orange button in, which releases the cable. Then make sure the shifter is still in dead center, I pushed it slightly up towards 3 to give me more rear travel. Then release the orange button and you should be good to go. If it's still not good try again, if you went too far same thing, just try again, it's real easy. You don't nessarily have to be driving to feel if you did it right. Once you lock the the cable back on go row thru the gears and see if you can get to all of them before lowering the car."
once again i tried that and i couldent depress the orange button, any hints for getting it depressed?
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 1,336 |
There a very small tab that you must press to release the spring loaded orange button. So, when you are done adjusting and need to press the orange button back in, you must press it in all the way until it snaps past the little white tab. If the tab is broken, you are screwed and must order new ends. I will take pictures tonight of what I'm talking about.
Posts: 1,336 |
Originally posted by fastcougar: There a very small tab that you must press to release the spring loaded orange button. So, when you are done adjusting and need to press the orange button back in, you must press it in all the way until it snaps past the little white tab. If the tab is broken, you are screwed and must order new ends. I will take pictures tonight of what I'm talking about.
Time go away from me last night and I never took pictures ... does this make sense, or should I take pictures?
Posts: 3,637 |
take some pics. I was under the impression that you just push the Orange part into the white, that disconnects the cables, you move the shifter to where you want, then release and its locked in place.
230.2 WHP @ 6500
237.0 WTR @ 2250
