Posts: 3,867 |
...underneath the IMRC cover (the black plastic decorative piece.)
What does it do? (It's a 96 Duratec)
It's obviously cracked from age and needs to be replaced before it fails entirely. It looks like the OEM piece is a shaped piece of hose, which gives it a neat appearance, but I can't find a part # or even a diagram anywhere.
When you guys replaced it, what did you use? Just standard vacuum hose?
TIA
Function before fashion.
'96 Contour SE
Posts: 4,140 |
Mine goes to a hole in the valve cover.
Posts: 3,867 |
Originally posted by Auto-X Fil: Mine goes to a hole in the valve cover.
yeah, mine does too. I just couldn't remember where it went after it disappeared under the heat retainer.
'96 Contour SE
Posts: 3,867 |
Originally posted by Tony2005: Originally posted by RogerB: ...underneath the IMRC cover (the black plastic decorative piece.)
Part of the crankcase ventilation system. Fresh air source according to Autozone.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/c9/df/0900823d801bc9df.jsp
OK. Any special specs on the hose?
'96 Contour SE
Posts: 980 |
I just ordered that bugger from teamfordparts.com It was ~$13... Shameless plug
2000 Mystique LS
Duratec 2.5L MTX
Posts: 3,867 |
Originally posted by Tisby: I just ordered that bugger from teamfordparts.com It was ~$13... Shameless plug
Does it have a name or a part number?
Has anyone just used standard bulk hose in that location? And if so, what? Seems like standard vac hose would work, as it's not under much positive pressure, right?
'96 Contour SE
Posts: 980 |
Don't have the part number or the exact name, but it's
"TUBE ASSY-CRANKCASE" for $13.97...
2000 Mystique LS
Duratec 2.5L MTX
Posts: 3,867 |
'96 Contour SE
