...and before you remove the fuel filter, unscrew the fuel filler cap to help relieve the fuel pressure from the fuel line on that end. Helps prevent a lot fuel spraying on you when you are under the car.
1996 V6 ATX 96K miles
Originally posted by Tony2005: ...and before you remove the fuel filter, unscrew the fuel filler cap to help relieve the fuel pressure from the fuel line on that end. Helps prevent a lot fuel spraying on you when you are under the car.
That is some good advice. Gas in the eye HURTS ! Believe me!
Also be prepared that some WILL leak out no matter what you do.
The How-to is good, and it is a simple item to replace.
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
