Posts: 993 |
I have a couple of questions and figured just faster to ask them than to search them. Yes I am lazy.
Those of you who use a friction modifier in your transmissions, what brand do you use, like and where can you buy it and how much?
Does the SVT Contour have a hydraulic clutch or a cable?
Thanks,
1998 BLK SVT CONTOUR
#2980 of 6535
395,000(ish) km (and counting)
SVTOA-TORONTO
Chapter Director
www.svtoa-toronto.ca
Posts: 1,101 |
Laura....you know I'm a good resource for you.
For the friction modifier I believe it was a Ford part number XL-7 or something. If you ask for "old stinky" when you say friction modifier the parts guy should know. Be sure to use at most 1/2 the bottle.
As for the clutch, yes it is hydraulic. The bleeder is on the bell housing rougly under the WP pully area.
Any other questions?
Posts: 993 |
Thanks Evan. Yes you are a good source.
Does the friction modifier have to be a Ford product, is there not something made by lucas oil or whatever that is good too?
#2980 of 6535
SVTOA-TORONTO
Chapter Director
Posts: 1,101 |
To be honest I am sort of undecided on the whole friction modifier issue.
If it wasn't so expensive I would go with the Ford Honey. Reason being is that yes the friction modifier does improve shifting in the short term but who knows what it can do over a longer period of time since the trans was not designed for it.
Posts: 993 |
I hear yah but I am having issues that I thikn it will resolve. Just have never used it before and dont know what brands to use.
#2980 of 6535
SVTOA-TORONTO
Chapter Director
Posts: 1,101 |
Go with Mobil1 ATF and the Ford Friction Modifier (XL-5 or XL-7, can't recall which one). That seemed to work best for me untill the 2nd gear syncro was on it's way out.
Posts: 993 |
Okay then thanks so much. Yes I already use Mobil 1
#2980 of 6535
SVTOA-TORONTO
Chapter Director
Posts: 234 |
I am now using Mobil1 and XL-7... and if you really want I have a few XL3 & XL7 bottles sitting in my garage that I need to get rid off..
but I am not happy with that combo.. this winter it wasn't the best for me.. in the summer and when its warmed up its fine.. but when cold crappy..
I am switching to Royal Purple Synromax before this winter..
hope that helps. Cheers
98 Contour V6 MTX
CTA Exhaust/CTA Intake/MSDS Y-pipe/Bat Handling Kit/Predator Alarm/Spec1 Clutch Kit/SVT Flywheel/G Assurances
Fix your car yourself "It's not a UFO." Todras
Posts: 644 |
I've tried everything from the Mobil 1 "cocktail" to Ford Honey (with and without FM) to ATF+3 to Synchromax, and the Synchromax is the hands down winner as far as I'm concerned. Definite improvement when shifting in the cold, and on par with the Honey in the warm. It doesn't hurt that it's less than half the price of Honey, and it's easy to sqirt in the tranny via the squeeze bottle, too!
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 993 |
Where can you buy the royal purple and how much does it usually cost?
#2980 of 6535
SVTOA-TORONTO
Chapter Director
