Posts: 234 |
I got it at Cobra in Mississauga.. its like $11/L or something like that.. you need 3L of the stuff.. They also have it at Performance world in Brampton.. and if that doesn't help you go to Royalpurple.com and check the retailer locater  cheers Martin
98 Contour V6 MTX
CTA Exhaust/CTA Intake/MSDS Y-pipe/Bat Handling Kit/Predator Alarm/Spec1 Clutch Kit/SVT Flywheel/G Assurances
Fix your car yourself "It's not a UFO." Todras
Posts: 644 |
Originally posted by lauraq: Where can you buy the royal purple and how much does it usually cost?
I bought it at Pure Muscle & Performance in Mississauga - my brain is a bit foggy at the moment, but I think it was $16 per litre.
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 1,043 |
I've seen it at some CT's. DaSilva should have it, as well as other speed shops.
Posts: 2,974 |
Laura, I don't know how close you are to Newmarket, I know Wes (1FASTDAD) got his Royal Purple from a shop called Overdrive.
Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Posts: 375 |
I would agree that the RP Syncromax is the way to go.
I've had the mobil 1, with the ford FM and although that had a smoother feeling shift, there is some speculation that the FM (Friction Modifier) has contributed to some premature wear. (or at least that's my take on the issue)
RP Syncormax is also available at any Performance Improvements, at a cost of ~$11.00/quart.
Hope this helps.
John.
96 LX 3.0L MTX - Black/Tan
K&N; 12lb F/W & uprated clutch
2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod;
UN-tuned Mod; 3rd Gear Synro-Crunch Mod
280K on the Shell, and 40ish on the Motor... 1/4 mile??
Yeah, it's a fun daily driver...
Posts: 970 |
I use the ford XL stuff. Just ask for Mr. Stinky!!!
98 GL sport (V6 MTX)
The Durable Duratec? - (DMD, Metal impeller WaterPump, Synth & Stinky in the tranny)
