Posts: 3 |
I've searched and I've seen this issue mentioned on the V6's but not the 4's so I'll ask. My 5 speed Mystique rpms don't fall between shifts. If anything they pick up a few rpms initially then after few seconds they will eventually fall. Any help would be GREAT!
Posts: 5,345 |
1996 V6 ATX 96K miles
Posts: 7,117 |
Check your throttle cable too. If it's frayed or crimped, this can be a dangerous condition.
Posts: 1,651 |
Originally posted by tbonester: I've searched and I've seen this issue mentioned on the V6's but not the 4's so I'll ask. My 5 speed Mystique rpms don't fall between shifts. If anything they pick up a few rpms initially then after few seconds they will eventually fall. Any help would be GREAT!
You have a bad throttle position sensor. Go to the ford dealer and get a new one.
TPS sensor tell them. $43.00
My car did the identical thing.
So tps is your answer.
Have a good day
I reject your reality and substitute my own.
Posts: 3 |
Thanks for the help. Is the TPS an easy do-it-yourself project? I haven't had the car long and have been under the hood very little.
The local dealer wants $55 for one. Is that something I can get at Autozone or is that one you need to get at the dealer?
Posts: 980 |
Originally posted by tbonester: The local dealer wants $55 for one. Is that something I can get at Autozone or is that one you need to get at the dealer?
I dunno about AutoZoo or Advance, but teamfordparts.com has it for $26.33. That's less than half of what you have to pay at your dealer. Granted, you'll have to pay shipping, but it's still worth saving the money. Shipping is cheap AND fair from them too...
Also, I'd go ahead and clean the TB now and inspect the cables while you're at it. Cheap and easy first...
2000 Mystique LS
Duratec 2.5L MTX
CEG road warrior
CEG road warrior
Posts: 17,248 |
With the TPS, if they are the original screws make sure to pull off the TB and size the bit/screwdriver to the screws accordingly. They like to strip.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 980 |
Originally posted by Evo-Twin-red: With the TPS, if they are the original screws make sure to pull off the TB and size the bit/screwdriver to the screws accordingly. They like to strip.
Ahh... the wise voice of experience!
2000 Mystique LS
Duratec 2.5L MTX
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Tisby: Originally posted by Evo-Twin-red: With the TPS, if they are the original screws make sure to pull off the TB and size the bit/screwdriver to the screws accordingly. They like to strip.
Yes....nothing like drilling out screws on a TB.
Hector
257HP/259TQ
160HP/141TQ
