Page 5 of 5 1 2 3 4 5
#1575766 05/24/06 07:27 PM
Originally posted by Decepticon:
i would have to show you, its flathead screw with like a 1/4-1/2" head with a washer/nut behind it.
Works well
hmmm... sounds like a good idea. where'd you come up with that?
#1575767 05/24/06 07:30 PM
RawBurt Offline OP
Works well
Ahh, If this is what you did Mx can you please tell me. I searched and found that you went around the dzus fastener route. What store can I get this from, I need to pick this up TODAY.
#1575768 05/24/06 07:37 PM
ace hardware. do you have the pic of them, or do i need to dig it up?
edit... nevermind, i found them.
ignore the bottom parts of the pics where it shows it with a nut on it. i was using the nut as a spacer (which you may need to do as well, depending on the length of the bolts they have).
this is the top half of the nut/bolt setup...
and this is the bottom half...
#1575769 05/24/06 07:38 PM
RawBurt Offline OP
I dont have a close up, if you could dig some up. I'd love you forever
#1575770 05/24/06 07:49 PM
Captain Impound Boy
Captain Impound Boy
Works well
Mine is slightly different!
Pole i don't like the durability either of duplicolor
#1575771 05/24/06 08:48 PM
Y
Y
What Jim and myself used, are torx bit bolts with a rounded head, with a locking nut on the back. They're small and unnoticable, and easy to remove.
Mark
#1575772 05/24/06 10:05 PM
H
H
I just used the bolts that came with the kit when i put my mirko on.
1 on each end. Easy to put it on and off the car.
I reject your reality and substitute my own.
#1575773 05/25/06 12:25 PM
RawBurt Offline OP
Yup this is what I ended up doing. It would be nice to have quarter or half turn fasteners, but its not a big deal. It takes me no longer the 60 seconds to remove the installed mirko.
Anyway, last night I got a coat of paint on. Tonight, I'll wetsand with 1000 grit, shoot another coat of paint on and let dry for the night.
#1575774 05/25/06 09:53 PM
What good id that splitter if your UIM isn't honed?????
PM me for a fix....
www.ChicagoCEG.com 2006 White Grand Prix
#1575775 05/26/06 12:25 PM
RawBurt Offline OP
Your a funny guy, save it for your contour...
