Page 4 of 5 1 2 3 4 5
#1575756 05/24/06 02:35 PM
Captain Impound Boy
Captain Impound Boy
I got some screw/nut combo from Aco.
#1575757 05/24/06 02:38 PM
RawBurt Offline OP
O rly?
Please elaborate.
#1575758 05/24/06 02:44 PM
Captain Impound Boy
Captain Impound Boy
i would have to show you, its flathead screw with like a 1/4-1/2" head with a washer/nut behind it.
Works well
#1575759 05/24/06 02:58 PM
Originally posted by RawBurt:
I'm going to need to wet sand the paint I have a feeling. The mirko is not easy at all to spray, its no flat surface thats for sure. The wet sanding wont take away from the silver frost shine will it? I shouldn't have to worry about it dulling or anything?
No it shouldn't be a problem as long as you have enough material built up...if you can try to get a good smooth coat on before you clear that would be best, just make sure you're overlapping wet areas.
Don't paint in direct sunlight & as long as it's not too hot where you are painting, you shouldn't have a problem w/ it drying too fast on you (which is where you'll have problems blending each pass & creating orange peel)...once it's dry enough to handle, you can move it into the sunlight to hasten drying/curing & evaporating the solvent.
1000-1200 grit is fine for in between coats. I'd finish w/ 2000 on your final clear. Just remember all sanding once you've begun painting is all wet sanding. If you can get ahold of an orbital or PC to do the initial buffing, do it. You'll be surprised at how quickly the finish brightens. Yes, it's a small piece in relation to the entire car, but a polisher will work...low speed
1999 Sportage 4x4...don't go there, it was free ....______o_o .../_l l__\____\ ..|--l l__----[]\|/[] .....................oo =( )_)----( )_)--)_)
#1575760 05/24/06 03:01 PM
RawBurt Offline OP
Thanks SVZETEC, this has been very helpful.
#1575761 05/24/06 03:03 PM
Im not sure how much paint you plan to have built up using a spray can, but generally rattle cans do not build up well at all. Anything under probably 10 freaking coats will come right off with wetsanding.
#1575762 05/24/06 03:06 PM
Captain Impound Boy
Captain Impound Boy
when i painted mine and the bike i sprayed 2 primer then sanded, 4 layers of color, 2 clear 1000(wet), 2 clear 1500 wet, 2 clear let sit then wax
#1575763 05/24/06 05:11 PM
What brand of pruduct did you use for paint?
#1575764 05/24/06 05:42 PM
Captain Impound Boy
Captain Impound Boy
duplicolor
#1575765 05/24/06 06:03 PM
duplicolor
I'm not happy with the durrablility of the Duplicolor finish on my splitter.....i'll keep looking i guess.
