Posts: 6,791 |
30 days, I dont know if I can wait that long  Thanks for the advice swazo.
Posts: 6,106 |
Nothing too harsh, as to avoid having scratch marks.
Get a nice coat of primer on there. It shouldn't take long at all to dry. Apply a thin coat of paint to avoid running. Wait until it's a little tacky, and spray another coat. Coat the Mirko until it's covered. Let it dry completely. Spray with clearcoat in a little thicker layer, as you'll be able to tell when it starts to shine that you've got enough on there. Let it dry, and apply another coat. Keep doing this until you're happy.
Mark
2000 Black CSVT
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Yes i painted my Rawburt. I need to do it again as there is a huge chip now
Posts: 4,970 |
In all honesty, I think I only waited 2 weeks. But 30 days would be ideal.
No matter what, if something nasty enough actually removes fiberglass when it hits it..... it doesn't matter how much clear is on there or how cured it is. But for 99% of what's going to hit it will have a lot harder time in chipping it if you do let it cure.
Look at the bigger picture. How much time do you want to spend in repairing your mirko and/or it's paint? If you do it right the first time, you'll save a lot more time in the long run.
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 674 |
Lots of helpful hints here guys. I'm planning on tackling my sideskirts and this thread will definitely help. Thanks!
Posts: 6,791 |
I sanded the mirko with 400 grit then shot some primer. Should I sand the primer, and if so what grit?
Posts: 3,195 |
Wetsand w/ 400 grit & soapy water (carwash), put your paper in the bucket & use a sponge to keep the surface wet & soapy & wipe after you sand to check the smoothness...hose off, let dry. Wipe down w/ a tack rag & paint.
If you can still see deep sanding marks, repeat until smooth
FYI...make sure the primer's heavy enough not to sand completely through, you want a good surface for adhesion, and lightly sand around the edges...it's easy to sand right through those areas.
...and this is where you will get many different opinions
1999 Sportage 4x4...don't go there, it was free
....______o_o
.../_l l__\____\
..|--l l__----[]\|/[]
.....................oo
=( )_)----( )_)--)_)
Posts: 4,970 |
First off, what kind of primer? Etching primer is what you should have started with. Filler primer is what you should spray next, and that can be block sanded with 400 & 600. A sealer primer is purely optional, it'll give your top coating process come out that much better.
Second, 600 grit is fine enough to where you won't see the sanding marks when painted and clear coated.
Posts: 6,791 |
Filler primer is what I used.
Posts: 626 |
Originally posted by Decepticon: Yes i painted my Rawburt. I need to do it again as there is a huge chip now
ewwwwwww..
i knew it...
