#1574572 05/21/06 09:36 PM
I
iso50 Offline OP
I
I'm working on a 2000 SE with the 2.5 V6. For some reason I can't get the oil drain plug out. Using a socket is impossible due to the location of the exhaust system. I've tried using a wrench and it wont move. I'm trying to turn it counter-clockwise. The dealer has changed the oil on this care before. But I have no idea what they have done to it so I cant get the 15mm plug out. Any tricks to getting it out?
Welcome .
Get a 6-point 15 mm wrench ($8 at Sears) and drive the car until it is warmed up. It is usually easier to remove the drain plug when the car is warmed up. (or send it to the shop and have them do the oil change).
rubber hammer i have had to use this when i take the car some where and have it done. just give it a few hits and it will turn.
G/f's black 99se sport 5 speed 2 1/2 test pipe-custom cat back 3 single tip cai with kn3530 safc optimized tb 8mm plug wires spec stage 1 clutch svt front bumper
I
iso50 Offline OP
I
Seems like the answer is to get a bigger hammer
I
iso50 Offline OP
I
Didn't work. The dealer must have way over tightened it.
I had the same issue and just took it to Valvoline or any oil change place and told them the issue and they loosened it free of charge. Just an idea.
FS: Stock Diff. Stock Shift Forks SE Front and Rear Bumper
I
iso50 Offline OP
I
It was on so tight the dealer had to drill it out and put a new one on.
