I am looking to compare my dyno sheet with anyone else who has somewhat the same set up. I am mainly looking to see how much torque I am losing by not having any or very little back pressure. I have noticed since I got the entire exhaust system on that I seemed to have lost low end torque. I have been thinking of maybe puttung mufflers on to help this.
Here is a list of my current mods.
K&N Filter
BAT Intake Pipe
Ford Racing 9mm Plug Wires
Bosch Plat. +4 Plugs
Weaapon-R Headers & Y-Pipe
Flex Pipe
Test Pipe
TruBendz Standard catback w/Magnaflow straight thru muffler
Pics of Dyno Sheet
Thanks
Originally posted by Davo:
Good work, Dave. You're definitely the #1 interior guy around these parts; always innovating.
Redline Goods ShifterBoots:5% Discount
1) Backpressure helping low-end torque is a myth.
2) Your sheets look fine. You have gobs of low-end. Maybe you're just feeling it pull to redline harder because of more top-end?
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
I dont have headers on yet, only performance mods are intake, inlet pipe, sho shop y-pipe, and borla 2.25 exhaust.
Not sure if you can see the plot, but its 166 hp 153 tq as the highs. I hope to gain more torque with my headers!
Also the backpressure myth is indeed a myth, svtdriver's car dyno'ed higher on both torque and HP with no exhaust
W
W
Get rid of the bosch plats and get autolite double plats.
1999 Contour SE Duratec ATX My feet and the Stra�?Ÿenbahn http://www.tempo-topaz-performance.com/topazsho/ the coolest Topaz ever! To bad it's not mine
dito...Bosch plats SUCK!!!!
98 E0 SVT with some stuff
N
N
This is my un tuned 2.5 Mystique (and the installer has the MIL's on the primary O2 sensors.- I threw a code 10 minutes later..
151 HP 148 TQ
[image]http://www.cardomain.com/ride/2231339[/image]
Pete
Nice numbers.
99 Mystique 2.5l Koni/HR Suspension K&N Cold Air,Diablo Chip SVT TB, MSDS, OPT-Y, Bosal
Moderated by  mbb41_dup1
