Posts: 316 |
Mitsubishi Industries TD05-16G
Posts: 3,637 |
Originally posted by myconsvt: ok well i just talked to another tech at mt work and got some info on it so i should be good. installation begins when my dealer starts to get slow. my hoist has been pack the past couple weeks.
see you in 2 weeks when your differential blows up your transmission.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 98 |
The Evo turbo is a modified 16G. It uses a twin scroll turbine....I hope the techs are taking that into account.
Posts: 5,882 |
donated evo turbo $0 ADC turbo setup $$$$ reinventing the wheel PRICELESS! good luck, seriously.....no really. have there many, if any, successful home-made turbo installs on this platform? i mean any non-ADC turbo kits? i can imagine there were, but probably very few?
Posts: 2,097 |
hello!!! I am on my 2nd. Swazo's turbo worked great...the motor sucked! Warmonger did one and blackwidow. I won't count the front mount b/c it has some weird stuff.
98 E0 SVT with some stuff
Posts: 352 |
Instigator on the NECO boards did a GT35R FMIC kit...
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
Posts: 68 |
Yep..... now if i could get all the non drivetrain stuff to work right, i'd be in business
Cougar is no more, parts for sale.
Built escape 3.0 w/ 8.5:1 pistons, PnP heads, ovalport/mazda6 cams, SVT manifolds, the works
entire car for sale PM me if you want a part!!!
Posts: 46 |
yeah we talked about everything. and he should be the one to know because i got the turbo off of him and he does all of the srt 4 work in our shop. as long as i keep the boost down in a safe region i should be good. and he hooked me up with some oil and coolant lines. know i need to find a wastegate solenoid that will work on it.
98 black csvt
Posts: 3,637 |
Originally posted by myconsvt: yeah we talked about everything. and he should be the one to know because i got the turbo off of him and he does all of the srt 4 work in our shop. as long as i keep the boost down in a safe region i should be good. and he hooked me up with some oil and coolant lines. know i need to find a wastegate solenoid that will work on it.
Running like 3psi you should be safeish.. Dont count on anything tho.
230.2 WHP @ 6500
237.0 WTR @ 2250
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by gotapex: Mitsubishi Industries TD05-16G
Also, known as a "big" 16G. Like someone said is a a twin scroll design. Good up to 25 psi with no meth/water injection on the Evo.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
