Posts: 63 |
In the morning my brakes act like there is no vacuum at all - the pedal is rock hard. It also idles very roughly and stalls at first.
Then after 20 minutes or so the brakes are normal and the idling is better (though still a little rough). I have searched for vacuum leaks extensively, have replaced the egr, iac, and pcv valves, replaced plugs, wires, air filter, and cleaned maf.
The problem is worst on cold days, which makes me wonder if heat helps some rubber based vac leaks sort of seal up. No idea though.
Any thoughts?
'95 Contour GL 2.0l automatic, 110k miles
Posts: 6,910 |
ever change the fluid? its about time it not
I know my pedal was rock hard when abs was active until I changed the fluid
- 95 Mystique LS - Zetec/5spd
Posts: 63 |
No I have not, but I pulled the brake vac line and the vacuum was so weak that I am fairly certain is a vacuum problem.
Posts: 6,910 |
Originally posted by johnoh: Originally posted by BrApple: ever change the fluid? its about time it not
sounds like it might be, but the old brake fluid should be changed anyway
Posts: 63 |
found the leak. The wiring harness had burned a hole in the plastic brake booster tube, right near its knee.
Posts: 1,593 |
Originally posted by johnoh: found the leak. The wiring harness had burned a hole in the plastic brake booster tube, right near its knee.
Ah good job. I was just about to post that it sure sounded like a vacuum leak to me.
The brake booster is pretty easy to change, but what's up with something burning a hole in it? That sounds like something to be concerned about, doesn't it?
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
Posts: 63 |
Originally posted by Bicycle commuter : Originally posted by johnoh: found the leak. The wiring harness had burned a hole in the plastic brake booster tube, right near its knee.
The local dealer said that is a common problem for this car. The line sits up against something hot, though I can't tell what
Posts: 7,392 |
if your brake pedal is hard for four or more hours, please consult a doctor.
.....______
___|______\_____
|/-\_________/-\_|
.\_/...............\_/
Posts: 21,197 |
Must be close to the EGR/pipe or something on a Zetec.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 92 |
Just for future reference.
Same thing happened to me and it was the rubber gromet that goes into the brake booster.Had cut itself in half,outside looked fine but the inside was laying in the booster
