Posts: 21,197 |
Originally posted by Kremithefrog: 2 month old IAC valve popped a leak on me. It was leaking from the metal cap part of it. It happened soon after I did the TH fix.
TH says ...some of the IAC's with the cap...the cap is an atmosphere vent....with the TH fix you have increased the vac on the IAC and damaged the seal...hence leak to atmosphere....
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 6,106 |
Originally posted by todras: Originally posted by Kremithefrog: 2 month old IAC valve popped a leak on me. It was leaking from the metal cap part of it. It happened soon after I did the TH fix.
Is that cap supposed to be 100% sealed then? I know that when I sprayed mine with carb cleaner, it leaked out of that cap.
Mark
2000 Black CSVT
Posts: 3,076 |
ahhh, I did do the TH fix as well.. It sounds like this may be my issue.. I'll try a new IAC
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
