Posts: 636 |
I just got around to installing my triple gauge pod to see how everything would look. I want to install the Faze oil pressure gauge, but I'm not sure of the best spot to install the sensor? Has anyone done this before and if so where did you install the sensor?
Thanks.
-Mike
98 Contour SVT
Toreador Red #49 of 6535 Built on 3/25/97
WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower
85 Camaro
1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
Posts: 299 |
mechanical or electrical?
98' Black SVT
Build #1915 of 6535
Posts: 1,578 |
The "correct" spot to install is right behind the AC Compressor but many including myself have installed it in the cylinder head under the throttle body for the ease of installation.
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
98 'Tour SE 24V 5-spd
149 HP @5900
148 LB FT @4300
Posts: 636 |
Originally posted by hot3dog3lucky3: mechanical or electrical?
Electrical. I have a sensor that I'm trying to install.
Originally posted by 00_HO_Contour: The "correct" spot to install is right behind the AC Compressor
Right behind the A/C compressor eh? Is there a pre-exisiting port that is being used there?
Originally posted by 00_HO_Contour: in the cylinder head under the throttle body
Any pictures? I'm trying to see where exactly your talking about as I have the same question above, is there a pre-existing port you guys are using?
Thanks for the help.
-Mike
98 Contour SVT
85 Camaro
Posts: 4,970 |
There are 2 allen head plugs on the back of each head. Waist of time even doing this, all you will have is a gauge that tells you nothing worth knowing.
There is the oil pressure sensor that's right by the A/C compressor, and an allen head plug that is just to the side of the OEM sensor. You can either use a brass "t" fitting and sample the oil pressure from the same location as the OEM sensor, or if you can get to the allen head plug you can use that.
I ditched my A/C because of my turbo system, so I don't know if the plug in the block is accssable with the compressor inplace.
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 21,653 |
Originally posted by TC'd Swazo: There are 2 allen head plugs on the back of each head. Waist of time even doing this, all you will have is a gauge that tells you nothing worth knowing.
Are you saying oil pressure isn't worth knowing? It's what some others (demon,etc.) said should be the first gauge to get.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 4,970 |
No, getting your pressure from the back of the head isn't worth knowing. It'll make your gauge work, but the data you get is worthless.
The only way to go is from one of the two options for the block I listed.
Posts: 6,910 |
well I think another option would be to put the gage on a remote filter as i believe that the oil filter is the first stop after the oil pump
- 95 Mystique LS - Zetec/5spd
Posts: 1,978 |
I have my electric plumbed to the remote oil filter, the readings still appear to be low, but I think thats just because its not mechanical. Im pretty sure todras is seeing accurate number with his mechanical gauge from the filter
Alex
'99 SVT Contour
Posts: 21,653 |
Originally posted by TC'd Swazo: No, getting your pressure from the back of the head isn't worth knowing. It'll make your gauge work, but the data you get is worthless.
Ok my bad.
Warmonger and maybe others said that having it in the head could possibly show a pressure drop sooner...
98.5 SVT
