Posts: 6,760 |
Originally posted by silverchris: Bump. I cant find it
here
Ryan
Trollin!
Posts: 23 |
See that is the one the parts store gave me. but i thought this is the one with the long bolt like terminal not a plug.
91 Mazda 323 -soon to have 1.6l turbo swap
95 Ford Contour -stock
Posts: 190 |
I just went to Autozone to get the part and they gave me that same part. They told me to try Napa or some other store, but they were already closed. I don't know where to find the part either...
1998 Silver Frost CSVT
#4427 of 6535
Born January 15, 1998
AIM: cannondale828
Posts: 5,345 |
You need Wells TU205 for the Temperature Gauge Sender (Switch).
_____________________________________________________________ Home > Repair Guide - Year > Repair Guide - Make > Repair Guide - Model > Ford Contour/Mystique/Cougar 1995-1999 Repair Guide > General Information > SENDING UNITS AND SENSORS > 6 Cylinders 155 L 2.5L SFI DOHC Search Results: TEMPERATURE SWITCH Click "Buy Online" beside the item you'd like to purchase from AutoZone.com.
Click "Add to Store List" beside the item you'd like to add to a shopping list that can be sent to and paid for at your preferred AutoZone store. TEMPERATURE SWITCH for a 1996 FORD CONTOUR Normal Stock Special Order Not Available
Item Part No. Warranty Core Value Unit Price Availability Store Web WELLS TU205 $17.99 Related Parts Related Parts are the items we recommend replacing (or inspecting) when you replace your TEMPERATURE SWITCH. COOLANT TEMPERATURE SENSOR for a 1996 FORD CONTOUR
Item Part No. Warranty Core Value Unit Price Availability Store Web WELLS SU284 $17.99 _________________________________________________________
1996 V6 ATX 96K miles
Posts: 23 |
Thanks  Now to find it locally hopefully
Posts: 190 |
I went to Autozone with the right part number. Thanks Tony2005!
They did not have any at the store in down but they did in a few towns away so they had it delivered this afternoon and I will put it in tomorrow.
#4427 of 6535
AIM: cannondale828
Posts: 190 |
I got it installed and the gauge is working perfectly! It was such an easy fix. Thanks!
#4427 of 6535
AIM: cannondale828
